Acceleration Shudder
  • 1 Post By NitroPT
Old 13 Oct 2016, 10:33 pm
Default Acceleration Shudder
2004 Turbo with an automatic and 73,000 miles. On normal easy acceleration, everything is fine. Upon moderate to hard acceleration, there is a definite shudder somewhere in the front end.
Where do I start looking ?
Transmission ? CV joints ? Motor mounts ? This is a new one to me from having had three Cruisers so far.
Mark.
Old 14 Oct 2016, 12:25 am
Default Re: Acceleration Shudder
I would suggest checking the upper and lower motor mounts first.
Old 14 Oct 2016, 07:05 am
What Steve said. And if that's not it, you might try rotating the tires and see if it moves to the rear. If not that, then take a look at your axles.
Old 14 Oct 2016, 08:34 pm
Thanks guys - gives me some place to start looking.
Mark.
Old 14 Oct 2016, 09:24 pm
You said Re: Acceleration Shudder
If no DTC(s) then it is drive-train related. The engine struts as Steve said are the first but if you are accurate with your description then you may have the week end task of replacing the the lower engine mount.
I hope it is the easier to find at fault
Good luck!y
Old 16 Oct 2016, 11:34 am
Good luck!y
So, I understand that there is a upper engine torque strut and a lower torque strut. You are saying there is a "lower engine mount",,, which lends me to believe there is a "upper engine mount". Where might that be?
I have a 2008 pt cruiser, 2.4 non turbo, automatic
Old 16 Oct 2016, 11:58 am
Sorry about that! I need to pay more attention to details! I met upper and lower motor mounts as NitroPT posted.
This is the upper motor mount.
Old 26 Oct 2016, 06:04 pm
UPDATE ....
Both motor mounts were shot along with both a-arm bushings. All is good and solid now. Thanks for the help guys.
Mark.
Old 29 Oct 2016, 04:27 am
Ok, after having some time to really drive the car for a few days, I will say the repairs have made it considerably better, but not completely.
I can still sense a bit of shudder on acceleration. Replacing the two engine struts helped considerably though. This is what I'm noting at this point ....
- Car idling, runs very smooth (just did tune-up)
- Car in drive, brakes on, very noticeable vibration
- Apply slight throttle (brakes still on), vibration gone
- Brakes on - turn on A/C, vibration gets considerably worse
I believe whatever this vibration is, is translating into the shudder I feel when accelerating. My mechanic is thinking it may be the main motor mount needs replacing as well - that's a tough one.
What say the resident experts here ?
Mark.
random shudder edb General PT Cruiser Discussions 4 18 Dec 2012 06:57 pm
Engine shudder with ac and heater rick2542 Tech & Performance Forum 2 29 May 2012 09:56 pm
shudder and sputter when in 4th gear pppt03turbo General Turbo Discussions 2 25 May 2012 08:35 pm
Cold start shudder ptguy69 Tech & Performance Forum 4 20 Jun 2011 11:14 pm
Light Shudder On Acceleration bob2006 Tech & Performance Forum 18 21 Dec 2010 03:30 pm
