Lower radiator support and central motor mount
Old 15 Oct 2016, 02:13 pm
Default Lower radiator support and central motor mount
Hello,
I'm having a small coolant leakage problem in my 2008 PT Cruiser Touring AT (108800 miles). So, looking for the problem, went below the car while checking the radiator (yes.. seems it is leaking between plastic/aluminium) I notice two other issues that I'd like some guidance.
First, the central motor mount seems to be cracked. I'd like to hear your opinion. Here goes a photo.
Second, the lower radiator support doesn't have a hole below the drain plug for coolant draining. Do you think it isn't the original one and was replaced somewhere in the past?
thanks!
Lucas
Old 15 Oct 2016, 03:19 pm
rckstein's Avatar
Default Re: Lower radiator support and central motor mount
That's the lower torque strut in your first pic, the center motor mount is different. If you replace the lower torque strut, you should probably also replace the upper torque strut at the same time, and there is a specific adjustment procedure that needs to be followed.
Needs Lower Cross Member Radiator support Soulman Classifieds: Want To Buy 13 14 Sep 2016 09:43 am
replaced upper and lower motor mount, still rough influenze Tech & Performance Forum 11 30 Oct 2014 11:35 pm
How to replace lower motor mount apalomo01 Tech & Performance Forum 17 20 Jul 2014 05:36 pm
Lower motor mount bolt sheered off invidious Tech & Performance Forum 6 16 Sep 2013 05:08 pm
Lower Motor Mount LooseJox Tech & Performance Forum 8 05 Jun 2012 09:26 pm
