motor mount, transmission mount and torque struts
Like Tree5Likes
Closed Thread
Old 16 Oct 2016, 11:28 am
Default motor mount, transmission mount and torque struts
So, I am trying to research all things concerning the above topic and I need to ask members on this forum... "Are the aftermarket mounts and struts comparable or as good as the oem products?" Quite a bit cheaper, but are they worth it? Are there better aftermarket ones than others? And just because amazon can sell some things for 1/4 the cost of others doesn't mean I'm going to buy it.
Old 16 Oct 2016, 12:27 pm
Default Re: motor mount, transmission mount and torque struts
ANCHOR mounts are used on most all general automotive forums and recommended most be the members on them.
To be very clear, ANCHOR will use the exact factory specification unless they find improvements to be made with all their mounts.
anchor-online.com : welcome to anchor industries
There is lots of opinions about this subject. I would recommend to us the search feature and you will find this very old and hashed over topic!!!!!!!!!
Old 22 Oct 2016, 08:44 am
Well, I took off the upper and lower engine torque struts two days ago for inspection and found them both to be cracked and broken in the rubber bushing area. Ordered Anchor products from my local auto parts store and installed them yesterday. I found it to be an easy job, even getting the top one out and back in without removing anything else.
I did the alignment using 4.7 inches center to center from the bolt to the little hole that holds the fuel line support.
It cured the "shudder upon acceleration" by about 90 per cent. But also, at the same time, the replacement of the struts made all contact points more solid and positive, thereby letting vibrations of the drive train flow more easily into the rest of the vehicle. So, sitting at idle it is not as smooth as before. I'm glad I did the job.
Does anyone know what the little hunk of metal that mounts on the end of the upper torque strut with two t30 screws is for?? Looks like an afterthought for a vibration dampener to me. Kinda silly looking thing.
NitroPT likes this.
Old 22 Oct 2016, 10:29 am
It was told to me by a Chrysler engineer (EP) that it was a way to help with harmonic vibrations at very low engine speed? Even he said that he never actually got to see the design specification and test sheet on it.
Only way to see if it really works is to use a vibration measuring tool.
I looked into this once and could find no facts to prove it worked or did not. So generally if the mount I get to replace on an engine has it I leave it if if does not I do not R&R from the old mount to new mount.
Old 22 Oct 2016, 12:36 pm
Do you have the pencil strut that is attached to the lower motor mount? Some members says strengthening of the front sub-frame always help but some mechanics don't bother to put it back on.
Old 22 Oct 2016, 01:08 pm
Yes, my cruiser does have the pencil strut and I did put it back on.
Old 22 Oct 2016, 02:13 pm
rckstein's Avatar
The OEM torque strut has some extra casting on the end, supposedly to help with vibration dampening.
Some of the after-market ones have a piece of metal screwed on the tab
Old 22 Oct 2016, 04:07 pm
^^^ does anyone really want to correct this guy...
It really does not matter but I do think it is funny!
05274903AD/04668195/04668195AB/04668195AC/05274903AA/
Old 22 Oct 2016, 05:55 pm
The pictures you show are the lower torque strut. I was talking about the upper torque strut.
But since you show those pictures, it's interesting how they look now. I bought the anchor brand and the lower torque strut I received does not have the screw-on metal plate nor does it have the extra blob of cast metal outboard of the large bushing mount. My guess is that it didn't do what it was intended to do in the first place.
Old 22 Oct 2016, 06:07 pm
rsrocket1's Avatar
There was a difference with the old and new struts with me too.
I think the new ones work just fine. They are so cheap and you now know how easy they are to replace that if you have to do it 2-3 more times in the car's life, it won't be a problem. If these don't last long, get the parts at Autozone. They'll cost 3X as much for the same parts you can get at Rock Auto ($30 vs $10), but have a lifetime warranty where you bring the old ones in and they'll exchange them for new ones.
Closed Thread
Engine mount/ torque struts BigApple Tech & Performance Forum 9 02 Oct 2017 11:22 am
Drivers Side Motor / Transmission Mount how to? rhino169 Tech & Performance Forum 1 20 Jul 2015 03:41 pm
How Hard Is It To Replace Lower Motor Mount (Torque Rod)? myjeephatesme Tech & Performance Forum 16 02 Nov 2012 06:50 pm
Replacing Upper Torque Strut/Mount paulrosenthal Wheels, Tires, Suspension 9 11 Jun 2011 03:21 pm
Broken motor mount (Not torque struts) KustomKruiser Tech & Performance Forum 22 06 May 2011 05:39 pm
