PCM PLUG - LOCK CLIP BROKEN AND I AM VERY MAD
Like Tree6Likes
Old 16 Oct 2016, 07:01 pm
Default PCM PLUG - LOCK CLIP BROKEN AND I AM VERY MAD
Guys
I was cleaning the PCM connections and I broke one of the amazing weak plastic red lock clips.
I am not able to find the plug anywhere. Did you guys have this problem before.
I am so furious.. I hate this plastic parts.
Old 16 Oct 2016, 07:23 pm
Default Re: PCM PLUG - LOCK CLIP BROKEN AND I AM VERY MAD
Was it the red locking clip or the black tab that is broken?
Help
Old 16 Oct 2016, 08:43 pm
yes sir! the little red clib that we need to pull down to remove the connector.
Old 16 Oct 2016, 08:52 pm
this is not my picture but you can see the red clips here
http://www.ptcruiserlinks.com/galler...ertRepair4.jpg
Handy_Cruiser likes this.
Old 16 Oct 2016, 08:58 pm
Help
As you can see in the link that ptcruisersteve posted, we've been through this before... I have a donor car here now, I'm hoping to see if I can test my theory about removing good clips from a plug to replace the broken ones. Hopefully it works so I can get rid of the zip ties holding one of my plugs on!
Old 16 Oct 2016, 11:34 pm
Handy_Cruiser's Avatar
Yep,
That's my photo posted above. You can indeed replace the plug. It takes some time but can be done.
Old 17 Oct 2016, 12:08 pm
rob302's Avatar
i like the zip tie idea. simple and effective.
changing all those wires should go ok if you're detail oriented and familiar with doing that correctly. it could also be a very easy way to cause more problems.
just curious..why are you cleaning those connections anyways? are you fighting a bad PCM, chasing hopes and dreams, or..??
Old 17 Oct 2016, 10:45 pm
Because sometimes the car was not switching and the engine light was on. But if I park and turn on and turn off the car, everything is fine.
The mechanic took a look and he said probably is a bad PCM or a bad cable. The first thing that I tried was to clean the plugs but I have the same problem again, so I also need to replace the PCM.. or to re-program it which I do not know how to do it.. seems to be a software issue.
Old 17 Oct 2016, 10:46 pm
Rob, yeap!! I used your picture and many thanks for that. Please, when did you get the new plugs ?
Old 17 Oct 2016, 10:48 pm
Fk5 Fk5 is offline
I haven't broken the PCM clip, but I have broken my fair share of Mopar electrical clips. I have to say, for me the sequence is usually, I AM VERY MAD AND THEN I BREAK THE LOCK CLIP
rob302 likes this.
2003 GT 5 speed
162,000 miles
Tags
pcm plug cable clip
Broken crankshaft sensor clip. Is there cause for worry? Flash619 General PT Cruiser Discussions 9 08 Mar 2015 11:34 am
looking for the OBD2 plug clip dark1463 Classifieds: Want To Buy 6 21 Jul 2014 07:00 am
Auxiliary plug in jack loose/broken? in car radio.. quietcharm23 Sound and Security Forum 6 03 Nov 2010 01:16 pm
Rear hatch lock broken danbutler55 Exterior Accessories Forum 2 04 Oct 2008 07:03 pm
My power door Lock is broken... CemeteryCat13 Interior Accessories Forum 3 13 Sep 2007 05:11 pm
