Engine ticking on rpm up and down
Old 17 Oct 2016, 05:55 pm
Default Engine ticking on rpm up and down
Hi i am new to the forums but have done extensive research into what engine ticking can be. I have heard it can be fuel injectors, lifter arms, among other things. It seems to have progressively gotten worse. And I have only had it just over 2,000 miles (@126k]. 2006 non turbo. Done oil changes and tried marvels oil as well per many good reviews on here. I just made a video of where the ticking seems to be coming from. Thanks in advance.
https://youtu.be/nyvPKLrH3oA
Old 17 Oct 2016, 06:14 pm
rob302's Avatar
Default Re: Engine ticking on rpm up and down
is it as loud in person as it is in the video?
any change in sound when it's cold versus when it's at running temperature?
Old 17 Oct 2016, 06:17 pm
Yea it ticks pretty loud in person as well. Almost sounds like a ball bearing tapping around. On a cold start, revving the engine is much more pronounced than if you have been driving for 20 or so minutes.
Old 17 Oct 2016, 06:18 pm
rob302's Avatar
is it louder in back of the engine than in front of it? exhaust manifolds crack on these and can make a loud ticking too.
Old 17 Oct 2016, 06:20 pm
Also no check engine light and it drives beautifully. Seems to be a small leak in the radiator, hopefully from a hose, haven't checked it yet. Refilled with proper hoat engine coolant when it got low. No milkiness.
Old 17 Oct 2016, 06:22 pm
It seems like it is coming from where I pointed the camera. Possibly up front. Really hard to tell.
Old 17 Oct 2016, 08:03 pm
Sounds as if it has broken valve spring or colapesed lifter
What's this engine ticking? CdnCruiser Tech & Performance Forum 6 10 Mar 2016 12:35 pm
Engine ticking Evile Tech & Performance Forum 10 27 Sep 2012 09:45 pm
Ticking Sound in the Engine Tarek Tech & Performance Forum 2 28 Jul 2012 01:23 pm
Engine ticking baz Tech & Performance Forum 7 07 Apr 2012 08:44 am
