Car Won't Star Start After Tuneup
Like Tree3Likes
Old 17 Oct 2016, 11:54 pm
Default Car Won't Star Start After Tuneup
My 2004 non-turbo manual PT (200k mi) isn't starting. Hooked it up to a scanner and said something about a spark, so I changed out the spark plugs and wires. Started right up.
After a week I drove it with no problems then later that day it wouldn't start. I replace the ignition coil but still did not start. I think I should mention that it was overheating the day it stopped working.
Hooked it up to the scanner and got P0031 & P0037. I've known it's needed a new ECM for awhile but just haven't had the cash to replace it. Any ideas?
I've been reading around this forum for awhile trying to get answers but thus far nothing has worked.
Old 18 Oct 2016, 09:29 am
Default Re: Car Won't Star Start After Tuneup
Have you checked to see if the coil driver is working properly in the PCM? You should check to see if the two wires going to the coil are grounding properly to get spark or if you are getting power feed going to the coil.
Old 18 Oct 2016, 09:36 am
Fk5 Fk5 is offline
This is the kind of thread that usually causes fights around here. Like this is so close to our #1 complaint that it seems like trolling. I think the title is misleading. The car overheated and then wouldn't start? What/when was the tuneup? The changed plugs? The changed coil?
It sounds like you have an intermittent problem and you are throwing parts at it. You say that you knew that it has needed a new ECM for awhile now? Why do you say/know that? That could be the intermittent problem.
What does it do when it doesn't start? Is it not getting spark?
2003 GT 5 speed
162,000 miles
Old 18 Oct 2016, 10:02 am
Not going to lie I have no idea how to do that but I'm sure there is something I can look up. Thanks
Sorry I was just trying to give as much information as possible because I am noob. The car did start after overheating. Tune was done a few weeks ago. Same with the plug, changed the ignition coil yesterday.
I'm honestly desperate to ge this running so I basically am.I know it's needed an ECM because that's what the guys at the shop said when I took it a few years back.
Turns over but doesn't get a spark. (At least that I know of)
Old 18 Oct 2016, 10:22 am
I would suggest getting an spark checker to check for spark.
They are reasonable at Harbor Freight.
Search results for: 'spark checker'
Old 18 Oct 2016, 10:30 am
Fk5 Fk5 is offline
No need to apologize. As long as you are a human and not a troll and answer questions, respond and come back to tell us how the issue is resolved I am happy.
I find it hard to believe that the car needed an ECM "for a few years." It isn't really like a weeping valve cover gasket. Follow Steve's advice and see if the car has spark. If it doesn't we have to find out where it is missing. Plug, wire, coil, etc.
The two codes you posted related to O2 sensors and that generally will not cause a no start condition in my experience. More likely another symptom rather than the cause.
2003 GT 5 speed
162,000 miles
Old 18 Oct 2016, 10:42 am
Have you checked the grounds from the battery? You need to remove the battery and clean the posts and clamps THOROUGHLY. Then check and clean the grounds on the driver side fender. Check them closely. One could be corroded or broken. Clean and repair if necessary. If you don't have good ground, you won't get a spark.
Old 18 Oct 2016, 11:52 am
Because Trump
Fk5 and VsandFords like this.
Old 18 Oct 2016, 01:00 pm
Fk5 Fk5 is offline
Originally Posted by sanatanadharma View Post
More than one fuse on the PT Cruiser can cause the problem of which you speak.
Check your fuses.
Good advice. I thought of this, but it seems that the problem is intermittent. It started after he changed plugs then wouldn't again. Fuses are usually good or not. I think that relays act this way at times based on heat. ASD relay maybe?
2003 GT 5 speed
162,000 miles
Old 18 Oct 2016, 01:23 pm
Much appreciated guys!
I'm gonna start with checking the ground and the fuses then check the spark. Will report back... Again thank you so much for your help!
Tags
p0031, p0037, wont start
On-Star Mirror chiefsfanforever70 General PT Cruiser Discussions 5 28 Jun 2014 05:21 pm
5 Star Shine? PT-ERA The Detail Shop 6 11 Feb 2007 10:17 pm
Three Pointed Star turbomangt The Detail Shop 9 01 Dec 2004 11:00 pm
