GT Turbo P0335 intermittent failure
Old 23 Oct 2016, 05:54 pm
Default GT Turbo P0335 intermittent failure
2005 Turbo GT (76kmiles). Mods: Cold Air Intake.
Pt runs fine for 30 minutes, then shuts off fast, NO sounds/ no stall. Wait 30 minutes to cool down and runs fine again.
P0335 code, TRAC off light constantly ON, ABS ON.
Proceeded to change BOTH the crankshaft and cam sensors with genuine MOPAR. Same thing P0335.
Only happens when running; it can idle for an hour, no problem.
Any thoughts?
Old 23 Oct 2016, 06:48 pm
Default Re: GT Turbo P0335 intermittent failure
P0335 - Crankshaft Position Sensor Circuit:
Possible Causes:
1. Intermittent Crankshaft signal
2. Crankshaft Sensor signal circuit is open or it is shorted to ground
3. Crankshaft Sensor 5 volt supply circuit is open or shorted to ground
4. Crankshaft Sensor ground circuit is open
5. Camshaft Sensor is damaged or has failed
6. PCM has failed
Is there anything else does goes out when it happens?
Old 23 Oct 2016, 08:26 pm
When it happens everything else is normal. Car stays like when you turn the key to ON position without starting the engine. No Limp mode, No stall or hesitation...nothing. When working, runs fine, can rev and boost normal, past 5000.
I'm starting to think the PCM is gone.
Old 23 Oct 2016, 11:32 pm
I would suggest the next time the engine just dies pull the camshaft sensor connector and see if the computer still triggers the code for the camshaft sensor.
Old 24 Oct 2016, 08:07 pm
_PTGT03's Avatar
This is obviously your crankshaft circuit that is opening and causing the car to shut off. In fact one of my last cars I designed a circuit to open the crankshaft position sensor to shut the engine off at a stop to save fuel.
You should inspect the harness from the sensor back about two feet and check for corrosion, baked insulation, damage, and backed out terminals. you can get a good replacement from the wreckers and cut out the bad section and solder in or crimp in a replacement.
Old 25 Oct 2016, 07:29 am
Thanks. Wires? Sounds possible, I'll look for it.
Question: Why it only happens after 30 or 45 minutes?
Never when the engine is cold; No matter how many street bumps I get into.
this convertible GT is from a friend of mine. I work on toyotas and hondas.
Old 25 Oct 2016, 08:26 am
Wiring is possible. the 30 minutes is related to heat, the wire could have corrosion, then when it get hot enough the signal degrades to the point the car can't run. Check wiring, and don't forget. NEW parts mean, Never Ever Worked. Check the resistances of your old sensor and compare them to a new sensor. If they are the same, either both dead or both good.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 25 Oct 2016, 11:26 am
_PTGT03's Avatar
exactly. isolating to a component level and confirming a fault is important. the easiest way to check would be to remove the one plug from the computer and use two sewing needles inserted into the correct pins and then check with an ohm-meter. i can get back to you on the correct pinout. also while you check for resistance you can make a salt water bottle spray and aim it all around the connector and up the harness while moving the harness to check for faults.
Old 25 Oct 2016, 12:46 pm
I would also suggest hooking up the scan tool, drive it until the engine dies and see if the scan tool is still communicating with the PCM.
Old 25 Oct 2016, 01:00 pm
Fk5 Fk5 is offline
Pretty sure the trac light is a hint. I haven't had the problem, but I remember people posting about it being on and it relating to something else.
2003 GT 5 speed
162,000 miles
Turbo Failure Sparkles3891 General Turbo Discussions 3 29 Oct 2011 10:13 pm
Turbo Failure spindy General Turbo Discussions 5 22 Aug 2011 07:58 pm
Turbo Failure bakapuma General Turbo Discussions 27 31 Jan 2011 07:57 pm
2.4 L turbo failure blackrain Turbo Performance 7 17 Oct 2006 11:04 am
TURBO FAILURE! BUBBA-KONA General Turbo Discussions 24 21 Sep 2003 10:29 pm
