New gaskets and head won't start
Old 24 Oct 2016, 08:28 pm
Default New gaskets and head won't start
I have basically rebuilt the engine. It's got new chain, timing belt,complete gaskets from oil pan up. The thang just won't start. It is in time. Have changed can sensor,crank sensor, has new computer. Any suggestions I may have missed. Have plenty of fuel pressure at the rail.
Old 24 Oct 2016, 09:02 pm
Default Re: New gaskets and head won't start
I would stop throwing parts at it and perform some basic tests. Compression test, leak down test, check for spark and make sure the injectors are firing. Do all those tests and come back to the forum with your findings. We can offer some suggestions with your feedback.
Old 24 Oct 2016, 09:31 pm
Did you everything pulled to do all your work? Sometimes the cam sensor connector and the coil pack connector (which look the same) can be interchanged and put back on the wrong place.
New head gasket, now crank and new start... PTDriver231 General PT Cruiser Discussions 4 15 Mar 2016 09:37 am
Gauging Service Intervals - Head Gaskets EvilSpirit Tech & Performance Forum 12 17 Dec 2013 12:36 am
01 pt wont start after head work perez05pr General PT Cruiser Discussions 4 25 Nov 2012 06:27 pm
boost and head gaskets Jason_L Turbo Performance 11 01 Jan 2004 02:56 am
head gaskets Turbo Tommy Turbo Performance 5 17 Jul 2003 02:27 pm
