key and security systen question
Old 25 Oct 2016, 01:35 am
Default key and security systen question
when I bought my 06 the lights blinked when I hit the unlock button on the key. now they do not. Is something failing here?
Retired after 45 years, worked at various things, ran a business for a while.
Married 3 kids, 2 grandkids
Daily Driver 2006 PTC,
hobby car:87 Porsche 944, currently in restoration mode.
99 F250 for hauling stuff.
Old 25 Oct 2016, 07:16 am
Default Re: key and security systen question
Try resetting the computer by taking off the negative battery cable for 10 minutes. While the cable is off, step on the brake pedal. After 10 minutes put the cable back on and see if that helped.
Old 25 Oct 2016, 07:53 am
LionPT's Avatar
You can turn this feature on & off along with the horn.
If no one can help, I'll look for info when I get back home.
Old 25 Oct 2016, 08:09 am
I haven't tried it with the PT but on my old car, if you hold both the lock and unlock button, it changed the chirping when unlocking the car. Should hold for about 5 seconds and see the lights blink.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 25 Oct 2016, 03:29 pm
LionPT's Avatar
To Turn Off "Flash Lights with Lock"
NOTE: The "Flash Lights with Lock" feature can be
turned on or off. For EVIC-equipped vehicles refer to
Personal Settings (Customer-Programmable Features)",
in the "Electronic Vehicle Information Center (EVIC) If
Equipped" section of this manual. For non-EVIC-
equipped vehicles, perform the following steps:
1. Press the UNLOCK button for 4 to 10 seconds.
2. While the UNLOCK button is pressed, (after four
seconds) press the LOCK button. Release both buttons.
3. Test the "Flash Lights with Lock feature while outside
of the vehicle by pressing the LOCK button on the RKE
transmitter with the ignition in the LOCK position, and
the key removed.
NOTE: Pressing the LOCK button on the RKE transmit-
ter while you are in the vehicle will activate the Security Alarm. Opening a door with the Security Alarm activated
will cause the alarm to sound. Press the UNLOCK button
to deactivate the Security Alarm.
The "Flash Lights on Lock/Unlock" features can be
reactivated by repeating this procedure
Old 25 Oct 2016, 03:45 pm
rckstein's Avatar
What trim level PT do you have? Does it have the EVIC in the left hand bottom part of the instrument cluster? If you have the EVIC, there will be a button similar to resetting the trip odometer. If so, that feature is set through the EVIC.
Security System Question chuckles Sound and Security Forum 10 17 Jun 2011 05:47 pm
New security system careyk General PT Cruiser Discussions 1 30 Oct 2008 01:39 pm
Security for your PT Tee It High General PT Cruiser Discussions 12 23 Jan 2005 08:29 pm
security issues dollymama Interior Accessories Forum 3 20 Apr 2004 04:18 pm
Security question..... dbraveman Sound and Security Forum 12 07 Jan 2004 07:10 pm
