please help
  • 1 Post By CREWZIN
Old 25 Oct 2016, 03:49 am
Cuda's Avatar
Exclamation please help
i have a 2001 2.4 5 speed and driveing home the other day the car started chuging and then the engine light came on and then started to flash i got home and checked the codes and i got p0304 code #4 cyl misfire so i changed the plug and wire and still have this , i cleaned the coil with steel wool and still got the same code, any help would be greatly thankful
Old 25 Oct 2016, 07:13 am
Default Re: please help
Some reading for you......
p0304 misfire code
Error Code P0304 Cylinder 4 Misfire Detected
Still getting a P0304 Fault Code?????
Cuda likes this.
Old 25 Oct 2016, 08:28 am
Post a picture of the spark plug tip.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 05 Nov 2016, 08:42 am
Take a can of brake clean and spray it around cylinder 4 runner of the intake manifold. If engine idle drops, you need to change the gasket.
