Roaring and Surging
Old 27 Oct 2016, 01:11 pm
Default Roaring and Surging
I have a 2009 PT Base with a little over 91k milles with two issues. The first is the surging while idling, but it seems to only really happen when the A/C is on. The other is the loud roaring that you would normally think is the wheel bearings, it also starts vibrating when I get up to around 65+ mph. What else could it be? It's driving me crazy.
Old 27 Oct 2016, 09:56 pm
Handy_Cruiser's Avatar
Default Re: Roaring and Surging
First, is your check engine light on and do you have any trouble codes?
Old 27 Oct 2016, 10:09 pm
I would suggest you jack up the front tires and see if they still make the loud roaring and vibrations. This will help with troubleshooting where the problem might be.
Old 28 Oct 2016, 06:03 am
No check engine lights, etc.. Only annoying thing like that is the check tire gauge won't go off no matter what they do. lol
Old 28 Oct 2016, 06:57 am
Here' some ideas to get the ball rolling.
The surging may be due to either a vacuum leak or the idle air control (IAC) valve. The IAC valve sometimes because stuck due to carbon. It may or may not set off a trouble code.
The roaring is possibly a bad wheel bearing or CV shaft.
Roaring from front conleyrb100 Tech & Performance Forum 10 19 Jul 2015 09:06 am
Roaring sound from front wheels, Bad bearings? LoboMX Wheels, Tires, Suspension 6 17 May 2011 06:50 pm
Roaring Sound PT_or_not_PT Wheels, Tires, Suspension 1 06 Apr 2010 09:24 am
LF Wheel Grinding/Roaring Noise gmiller Tech & Performance Forum 4 23 Mar 2008 11:57 am
Roaring noise from the rear when reversing?(FIXED) Ctown General PT Cruiser Discussions 3 17 Apr 2005 02:51 pm
