PT Cruiser Forum Car Videos
Car Rims
Iridium Plugs
Old 16 Jun 2004, 12:10 am
luvmypt luvmypt is offline
Default Iridium Plugs
Has anyone tried the Denso Iridium plugs on their PT. I am looking to redue my plug and wires and perhaps coil. I have read of some increased performance with double platinum plugs but here that Iridium is even better. What do you all think.
Old 16 Jun 2004, 04:04 am
Sci-Fi Sci-Fi is offline
The Denso Iridium Spark Plugs are NOT designed for the PT. Plus you need to use a custom made spark wire set and a "special spark plug socket" in order to install and remove them. Do a search and you will find out the differences between the Denso and the stock spark plugs. Then you can decide whether or not you want to go with Denso's. Believe JeffB mentioned Neon 2.0L spark plug wires "MAY" work, but that doesn't solve the problem of having to use a lathed down spark plug socket that may crack or get lost. http://ptenthusiasts.org/PTForums/sh...=denso+iridium
IMHO, if you gap the Champion Double Platinum's or regular Champion spark plugs at .040 (the same gap that is standard on the Iridiums), you should see the same performance. Also, you can use any of the current OEM or aftermarket spark plug wires (Crane, Magnecore, LiveWires, Taylor, etc.) listed for your PT.
Old 16 Jun 2004, 08:24 am
MY OPINION:
The newer ignition systems put out all the spark you need when new. The plugs and wires are replacement items - I got the Champion platinums and Crane wires expecting them to last longer - and they are already past the stock stuff's lifetime (I have close to 75,000 miles on my PT).
As to Irridium plugs - HYPE.
The only way you'll see a performance benefit is if your current parts are below par and you restore spark to where it oughta be.
The above is MY OPINION.
Old 16 Jun 2004, 10:25 am
tpscruiser tpscruiser is offline
Like QSD said, a lot of hype.
I just purchased a set of Mopar performance wires (7.5mm spiral core) and they are marked 500 ohms/foot resistance. The short ones actually measured 309-311 ohms and the long ones are 384 ohms. The specs on the OEM wires call for a range of 2360-7070 ohms for the short and 2970-8910 ohms for the long ones. As you can see by the numbers, the performance wires should last a lot longer before they "ware" to the point that they would cause a misfiring problem. I am also installing the Champion double Platinum plugs, #7570, gapped at .040-.043 again for longevity.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 16 Jun 2004, 10:53 pm
Thanks for the input guys. I am going with the Champion double platinums and a set of Livewire wires. Lets see how that does and maybe add the Screamin Demon Coil later. Thanks again.
Old 18 Jun 2004, 03:01 pm
snakepitt1 snakepitt1 is offline
Buy the screamin demon coil directly from Performance Distributors in Memphis, TN. 901-396-5782 ask for Brian. Outstanding customer service as well as excellent pricing. Performance Distributors are the actual manufacturers of the Screamin Demon coil. Brian will not only get your part out, but if something ever were to go wrong, he, and the company, will do everything in their power to make you happy. I am a VERY SATISFIED customer. You can even mention my name to them.
Enjoy,
Scott Harris
2003 Black PT with ghost flames, Magnaflow exhaust, cold air intake, lowered, chromed and totally underpowered.
Old 17 Jul 2004, 06:49 pm
danrobjon danrobjon is offline
Monarch products makes a specially designed set of plug wires so that the iridium plugs can be installed. For around $100 total cost, this is the best performance enhancement you can make to your PT. Increased HP, increased fuel efficiency for that kind of money, you can't beat it. go to http://www.sparkplugs.com. Read next quarters Cruiser Quarterly for another fellows opinion who made the same mod.
Old 18 Jul 2004, 03:29 am
SteelBlueGT SteelBlueGT is offline
To be honest I rather doubt a coil or plug change will do anything for a PT Cruiser if the original coil/plugs are working properly. Need to put in a whole new performance ignition system if you want to upgrade and do any good and then only for WOT stuff!
Old 19 Jul 2004, 08:28 am
I Smell SPAM. Also cures bad breath, whitens teeth, ....
Old 19 Jul 2004, 12:16 pm
NVSB4 NVSB4 is offline
I've looked around and figured it was worth a shot. Mine are coming in this week.
Some other articles:
http://ptcw.truckmoxie.com/tenarticl...er_for_your_pt
http://www.sparkplugs.com/ptsrt4iridium.asp?s=1
It\'s never too late to have a happy childhood.
vB code is On
gapping iridium plugs Hill Cruiser General PT Cruiser Discussions 4 18 Oct 2005 10:53 pm
NGK Iridium Plugs...Questions I asked the tech crazie.eddie Tech & Performance Forum 10 28 Oct 2004 09:46 pm
spark plugs ote69 Turbo Performance 24 12 Oct 2004 01:44 pm
iridium plugs??? DARK270 Stage Turbo Kits 2 13 Aug 2004 07:02 pm
Denso Iridium Plugs gsharrock Turbo Performance 2 22 Jun 2003 09:09 am
  Car Insurance | Song Lyrics | Mortgage | Best Credit Cards | MPAA
