Fuel "regulator" in the center of fuel rail?
Like Tree2Likes
Old 04 Nov 2016, 11:58 am
Default Fuel "regulator" in the center of fuel rail?
So, can someone explain what this thing actually does, and why it is or is not necessary? How or why it functions?
I've found little info on it, most doesn't really explain it's function or purpose. If you have a working knowledge and understanding of this piece, maybe you could explain. I'm planning some fuel rail customizing, and should have a better understanding of this before I move forward...
Thanks!
Old 04 Nov 2016, 12:41 pm
rob302's Avatar
Default Re: Fuel "regulator" in the center of fuel rail?
The pump is the regulator. What are you talking about on the rail?
Old 04 Nov 2016, 01:25 pm
I understand the pressure regulator is in the tank. The cap looking thing in the center of the fuel rail. Supposedly some type of regulator.
Old 04 Nov 2016, 01:51 pm
rob302's Avatar
Can you post a pic? My fuel rail has nothing there. I looked on all data at the shop, I looked under vin g and vin 8 for turbos and neither shows anything there. I'm interested to see what exactly you're talking about. See attached
Old 04 Nov 2016, 02:16 pm
This thing here... which looks like nothing more than a potential fuel leak to me! It's a dead end system, so I don't get it...
Old 04 Nov 2016, 02:22 pm
rob302's Avatar
that's an accumulator. usually it's on the firewall. it dampens the pulses created by the injectors opening and closing. it's similar to why electronics have capacitors to smooth out the voltage
JoeX likes this.
Old 04 Nov 2016, 02:27 pm
Because Trump
Old 04 Nov 2016, 02:36 pm
That explains it, and makes sense. Makes sense why it's spring loaded. Thanks guys... mystery solved. Now I'm not sure if I need it...? I wonder if the SRT's have them?
Old 04 Nov 2016, 02:38 pm
rob302's Avatar
2008 is the first year that was on the fuel rail so either someone changed the engine, or bare minimum the fuel rail is not original to your vehicle.
do you still have an accumulator on the fire wall?
IMO best way to delete that would be to get a pre-2004 fuel rail so you have a schrader valve on the end in case you want to add a pressure gauge or at least be able to attach a fuel pressure gauge some day.
Old 04 Nov 2016, 02:40 pm
rob302's Avatar
..... dp
bullet aluminum fuel door "Cruiser" logo jetmax Classifieds: For Sale/Trade 3 16 Mar 2016 10:17 am
Fuel line to Fuel rail... PurpleHazePT General PT Cruiser Discussions 0 23 Aug 2014 01:43 pm
Fuel Injector "O-Ring" Replacement? pmcruiser Tech & Performance Forum 10 29 Sep 2013 08:05 pm
what size is fuel line from firewall to fuel rail chitownpt Tech & Performance Forum 2 18 Mar 2013 06:17 pm
