Camshaft Caps
Old 04 Nov 2016, 02:55 pm
Default Camshaft Caps
Do you think it s normal to have some differences between the cams caps bearing?,
PT CRUISER 2L 2000 STARTECH
PT CRUISER 2,4L GT 2004
CHRYSLER VOYAGER 3.3 1993
CHRYSLER VOYAGER 3.8 AWD 1997
CHRYSLER VOYAGER 2.5 CRD 2003
Old 04 Nov 2016, 02:59 pm
Default Re: Camshaft Caps
How much difference are we talking about?
Old 04 Nov 2016, 03:11 pm
It s hard to explain, but
On the first picture there is a difference as I try to show on the picture below
On the second picture it is equal
On the third, there is nothing
Old 04 Nov 2016, 03:12 pm
the others are more less equal as the second picture
Old 04 Nov 2016, 03:19 pm
Handy_Cruiser's Avatar
Are these from your 2004 GT?
Old 04 Nov 2016, 03:21 pm
yes my 2004 GT
Old 04 Nov 2016, 04:41 pm
Realy no big deal just deburing chamfer
Wont make any diffrance
Old 04 Nov 2016, 05:02 pm
rob302's Avatar
if you mixed those up or are unsure about how they go i would seek out a qualified machinist to figure out where they go.
i would bare minimum install them and make sure there is no ridge where the openings align. i would also measure with an inside bore micrometer to make sure all the holes are the same diameter and are not tapered from left cap edge to right cap edge. bare minimum after seeing there is no ridge, install the cam/caps, and use plasti-gage to see that it squishes out equally.
if i mixed those up and i was spending as much as you, i would likely have my machinist mill the caps feet a few thousandths and then line hone the journals.
i'm very picky and will not just throw stuff like that together. you shouldn't either, IMO.
Old 04 Nov 2016, 05:16 pm
rob302's Avatar
IDK or maybe i'm TOO much of a perfectionist? replacement camshafts
Old 04 Nov 2016, 05:18 pm
Caps are numberd front end and left or right
Look up cam shaft caps on google will see how they are numberd
Camshaft Position Ikster Tech & Performance Forum 7 26 Oct 2015 07:13 am
Camshaft and crankshaft bheffner PT Cruiser Convertible Forum 4 06 Oct 2012 04:40 pm
camshaft installation Rippsnorter Tech & Performance Forum 4 18 Aug 2012 03:01 pm
WANT TO BUY: 2.4L Camshaft Sprocket 76911S Classifieds: Want To Buy 5 06 Aug 2012 10:38 pm
Camshaft sensor? RedEmma Tech & Performance Forum 3 26 Jun 2012 01:45 pm
