Brake lights and amber turn signal lights come on at same time
Old 11 Nov 2016, 10:41 am
Default Brake lights and amber turn signal lights come on at same time
I have a 2006 PT, when you press the brake the brake lights come on but also the amber turn signals light as well, the car will not pass inspection like this.
Also there are no codes set but the brake light and air bag lights are on in the dash. I replaced the multifunction switch with a known good one. I also checked all the bulbs.
Any Ideas? Thanks very much.
Old 11 Nov 2016, 11:05 am
rckstein's Avatar
Default Re: Brake lights and amber turn signal lights come on at same time
Welcome to the forum
Old 11 Nov 2016, 12:20 pm
Did the brake light and air bag light come on at the same time?
Old 11 Nov 2016, 02:19 pm
Has someone replaced the bulbs in the turn signal lately? If so, you need to make sure that the correct # bulb was used. I bought a Nissan truck several years ago that had a similar issue and it was the wrong bulbs someone had stuck in the turn signal sockets. I got the correct ones and cured the problem.
Ignorance can be educated, crazy can be medicated, but there IS no cure for stupid.
Old 11 Nov 2016, 04:23 pm
VOS's Avatar
VOS VOS is offline
I just had a go-round with a taillight today.
"You'd think" it would be a simple bulb but no.....
A trip to the dealer for a new socket [$20] and I'm good to go.
"Along the way" is a common ground that might explain this case.
From my schematic check today, it would seem either the multi-switch or ground are all that could explain this case.
Turn Signals Lighting Up with Brake Lights PentastarThunder General PT Cruiser Discussions 8 03 Feb 2016 09:58 am
No Brake lights or tail lights/running lights kitzmann56 General PT Cruiser Discussions 8 14 Feb 2015 03:07 pm
Front Turn Signal Lights Turn On and Off When Applying Brake? Danny7627 Tech & Performance Forum 12 20 Jan 2014 09:42 pm
Headlight, Wipers, Turn Signal, Accessory Lights greasdawg General PT Cruiser Discussions 4 20 Jul 2011 12:01 pm
2006 - Turn signal/driving lights Tarnishedknight Tech & Performance Forum 10 02 Sep 2010 08:23 am
