01 cruiser dies while driving.
Old 18 Nov 2016, 06:34 pm
Default 01 cruiser dies while driving.
my 01 will die while driving down the road. when you try to crank it, you can hear the fuel pump kick in but it will just spin over. After waiting a few minutes, it will start and go down the road a ways and die again. have checked it and it is not throwing any codes.
Old 18 Nov 2016, 11:23 pm
Default Re: 01 cruiser dies while driving.
Check the wiring loom underneath between the cam and crankshaft. See if it dropped and is chafing on the halfshaft passenger side. If so, try to repair the damaged wires.
2016 Kia Soul Plus Black
Old 19 Nov 2016, 12:12 am
A similar thing happened to me with my Neon and it turned out to be a wire that the plastic covering had melted away from, allowing the wire to repeatedly short out the relevant fuse. So soyomb is right, check the wires for worn through or melted insulation.
I was able to repair it using regular and liquid electrical tape.
Old 28 Jul 2018, 11:12 pm
Had the same problem with my 01 cruiser. shop had it for a week. died on way to work the next day. three more times getting it home. back to shop. changed out the crankshaft sensor. have put about 250 miles on it since. even with a/c on, not a problem yet.
06 PT Cruiser stalls and dies while driving CruisingCalifornia General PT Cruiser Discussions 4 29 Jul 2015 10:05 am
2001 PT dies while driving....please help DallasTint Tech & Performance Forum 2 04 Mar 2015 04:38 pm
Won't crank sometimes - dies when driving - electrical issue? jmansour Tech & Performance Forum 14 23 Jun 2014 03:53 pm
Engine cuts out/dies...while driving ScottS Tech & Performance Forum 2 13 Mar 2013 07:37 am
2001 LE Cruiser dies while driving xebix Tech & Performance Forum 5 10 Apr 2012 10:48 pm
