05' PT, flasher relay keeps going bad
Old 20 Nov 2016, 05:24 pm
Default 05' PT, flasher relay keeps going bad
Hi there,
My parents have a 05 PT Cruiser. Flasher's stopped working, checked all fuses, and then moved on to replace the Flasher relay. That was a used relay from wreckers. It worked for a month or so, then it burnt out. Figured, it was used so maybe that was just bad luck. Got a new one from Napa and it worked for a couple of days and is bad now too.
Any ideas what could be the cause for this?
Old 20 Nov 2016, 07:34 pm
LionPT's Avatar
Default Re: 05' PT, flasher relay keeps going bad
Check your rear tail light bulbs..make sure there is no water inside lens.
Old 20 Nov 2016, 08:33 pm
VsandFords's Avatar
Welcome to the forum.
Old 20 Nov 2016, 08:46 pm
After posting this, my father was out looking at it, and with the flasher relay out, fuses are blowing when he puts them in, so he was figuring short in wiring somewhere. We'll check the back lights and see.
thanks for the suggestion, and the welcome
EDIT: just spoke to him and he already checked both back lights. Next ideas?
Old 21 Nov 2016, 12:30 am
_PTGT03's Avatar
get an electrical diagram for the hazards and warning lights circuit. trace the hot wire down from the fuse for a short to ground. then your problem will be solved.
Combo Flasher PTN General PT Cruiser Discussions 1 15 Jul 2013 02:21 pm
LED flasher CHARGERFORCE General PT Cruiser Discussions 5 28 Aug 2011 11:52 pm
Combination Flasher Pin Out glennmagor General PT Cruiser Discussions 1 12 Apr 2011 01:37 pm
SCT Flasher For Sale SilverSleeper Classifieds: For Sale/Trade 2 25 Feb 2010 05:59 pm
SCT Flasher For Sale SilverSleeper General Turbo Discussions 0 23 Feb 2010 04:27 pm
