Heater core replacement. Remove AC?
Like Tree5Likes
  • 3 Post By VsandFords
  • 2 Post By PTBoulderer
Old 21 Nov 2016, 05:27 pm
Default Heater core replacement. Remove AC?
2005 Base model, naturally aspirated. 5-speed. Red.
Hello all, this is my first post.
I have the telltale coolant smell in the cabin, as well as outside (but mostly inside). It gets worse as the heat is turned up. All signs point to heater core and/or inlet/outlet hoses.
I watched a video on removal, and everything seems relatively straight forward, until it skips the part about actually removing the HVAC unit which contains the blower, heater core, and condenser.
After looking at some other guides, they say to drain coolant system and recover refrigerant. I can do everything except the refrigerant part, because I'm avoiding buying those expensive tools.
I know there are several heater core threads already, but none mention the AC lines.
I definitely don't want to bring it to a shop, but I am not about to release refrigerant into the atmosphere.
What do I need to do?
Thanks.
Old 21 Nov 2016, 05:30 pm
rckstein's Avatar
Default Re: Heater core replacement. Remove AC?
Welcome to the forum
Old 21 Nov 2016, 05:39 pm
You might find this thread of interest?
Smells Like Warm Coolant When Heat is On
Old 21 Nov 2016, 05:40 pm
VsandFords's Avatar
Welcome to the forum from Texas. When you have a minute, go to new members and tell us a bit about you and your Cruiser.
Old 21 Nov 2016, 05:42 pm
VsandFords's Avatar
You can take it to a shop, have them evacuate the A/C, go home , do the heater core and then go back to the shop, at a later date, to recharge the system.
Old 21 Nov 2016, 08:13 pm
Thank you all for the welcomes! VsandFords, that's a good idea, I didn't think of that. It's the best of both worlds.
Any idea on how much that might cost?
rckstein and VsandFords like this.
Old 21 Nov 2016, 10:03 pm
VsandFords's Avatar
Every shop is different. Possible you have a shop in the area that will do it for less then $100. They will want to check for leaks before recharging.
Tags
ac lines, heater core, heater core replacement
A/C problems after heater core replacement Cruiserlover7 Tech & Performance Forum 2 03 Jun 2014 04:21 pm
Heater Core Replacement lmarkie74 Tech & Performance Forum 4 30 May 2014 11:02 pm
Heater core replacement, how hard is it? 32seventeen Tech & Performance Forum 16 06 Nov 2013 01:28 am
heater core replacement mdskinner731 General PT Cruiser Discussions 8 14 Nov 2012 06:35 pm
Heater core and rad replacement ddash General PT Cruiser Discussions 4 14 Sep 2010 06:35 pm
