4 cyl running on 3
  • 1 Post By quicksilverdon
Old 29 Nov 2016, 12:45 am
Default 4 cyl running on 3
Help! really need to find the problem here. She runs strong, no stall. rough upon acceleration due to the miss. all basic tune up done. not an 'obvious' issue it seems. been running this way for many miles now over the mountains and thru the woods, literally.
also, fog lights don't work, and rear windows, both, don't work...ideas?
Old 29 Nov 2016, 01:23 am
Default Re: 4 cyl running on 3
Welcome to the forum.
Engine light on?
If so what are the codes?
Has an engine compression check been done on all cylinder?
Old 29 Nov 2016, 08:46 am
rckstein's Avatar
Old 29 Nov 2016, 01:36 pm
VsandFords's Avatar
Welcome to the forum from Texas. Have you checked for a vacuum leak? Do you know which cylinder is misfiring? More info please, year, mileage, other specifics, blah, blah, blah.
When you have time, please go to the new members section and tell us more about you and your Cruiser.
Old 29 Nov 2016, 01:57 pm
Old 04 Dec 2016, 02:42 pm
Wink Re: 4 cyl running on 3
Like some others here have mentioned do you have more detailed information and specifically what has been done already. Fog lights issue is a common failure on the Pt, but don't change parts without troubleshooting first. Could be bulbs but the switch is a common problem on these and I believe members have posted some repair steps for the switch with pictures if you find it defective and choose to go that route. As for the miss, the checks that have been mentioned by other members would maybe give you some critical evidence to narrow it down. I personally like the recommendation of doing a vacuum check with a vacuum gauge. It's quick and easy and may also show you if you have a mechanical engine issue. The other ideas mentioned are great avenues as well.
Old 04 Dec 2016, 04:30 pm
Rear windows -
There is a lockout switch on the dash - and check that there isn't something laying on the "foot" switch between the seats.
thecabinguy likes this.
Still running hot! madeupofwires Tech & Performance Forum 2 21 Jul 2013 11:16 pm
Non running 2.4 Ltd Andymacc Tech & Performance Forum 4 03 Apr 2012 12:19 pm
02 running a little hot... 02ptlimited Tech & Performance Forum 8 22 Jun 2009 09:47 pm
up and running again careyk Canada PT Forum 1 19 Feb 2008 01:31 am
XM up and running CHROMEDCRUISER Sound and Security Forum 4 07 Jan 2005 07:22 pm
