Right brake light not working
Like Tree3Likes
  • 1 Post By VsandFords
  • 2 Post By Wajolu
Old 29 Nov 2016, 03:30 pm
Default Right brake light not working
Hello all,
I'm new to the forum and would really appreciate your help with my break light issue.
I have a 2004 PT cruiser and the right brake light doesn't work, while the left one does. I replaced the bulb with a new one but that didn't work. I also checked the fuses and they seemed good to me.
The tail light which is in the same bulb does work.
Any ideas???
Old 29 Nov 2016, 03:50 pm
VsandFords's Avatar
Default Re: Right brake light not working
Check for a bad connection in the socket or possibly a broke wire. I've had some older cars that the spring in the socket that pushes the contact against the bulb was bad or the socket was melted not making a good connection.
chuzz likes this.
VsandFords's Avatar
By the way, welcome to the forum from Texas.
Old 29 Nov 2016, 03:59 pm
rob302's Avatar
the left socket went bad on mine. twist/wiggle the bulb in the socket while having someone hit the brake.
if that makes it work and you decide to bend the contact in the socket out, be gentle. i broke mine and had to solder it. the brass is very brittle
Old 29 Nov 2016, 04:01 pm
Welcome to the forum.
Make sure you check to make sure the replacement light bulb has the same numbers on it or the equivalent.
Old 30 Nov 2016, 11:59 am
Thanks all!!! I will check the socket and wiring, and also double check the bulb to see if it's the same one.
I will post the results on here.
Old 30 Nov 2016, 12:46 pm
rckstein's Avatar
Old 07 Dec 2016, 12:50 pm
Good news! The light works when I wiggle it in the socket, so to be sure I'll get a new socket and the problem should be solved.
Thanks all for your help and the warm welcome to the forum!
rckstein and rob302 like this.
Tail light and brake light not working trtrtr607 General PT Cruiser Discussions 2 26 Apr 2016 07:57 am
2005 PT Cruiser left side brake light not working bbodb1 General PT Cruiser Discussions 6 27 May 2014 07:13 pm
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
Third Brake Light and Dome Light not working metalcruiser General PT Cruiser Discussions 5 27 Feb 2012 04:03 pm
high brake light not working bobcatss66 General PT Cruiser Discussions 3 10 Mar 2009 01:32 pm
