Clutch Pedal / Clutch
Old 30 Nov 2016, 03:12 pm
Default Clutch Pedal / Clutch
Hi Peeps, so far this is my 4th PT and I still love them, even when it goes wrong.
Clutch pedal suddenly went half way down before engaging, got home and next day went to go out and it hit the floor
any suggestions?
Old 30 Nov 2016, 04:14 pm
cruserdad1976's Avatar
Default Re: Clutch Pedal / Clutch
slave cylinder would be my guess did you check to see if it had fluid??
Old 30 Nov 2016, 04:33 pm
not checked yet, got van problems, so need to sort that first, but will look 2moro thanks
Old 30 Nov 2016, 05:31 pm
_PTGT03's Avatar
usually the plastic connector leading to the slave push rod breaks. check to see if it's damaged
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 07 Jun 2017, 02:28 pm
Do you know where to get a replacement part? I have a GT with a turbo. I can find the replacement part from Dorman but only for Non-Turbo cruisers. I spoke with Dorman and they claim do not make a part for the Turbo model. It also does not appear to be a part you can get from chrysler/dodge/jeep direct. You can get the bushing, but not the plastic connector piece (See attachment.
Any thoughts?
GT CLutch pedal adjustment VNT General PT Cruiser Discussions 5 19 Nov 2016 04:07 am
Clutch pedal switch Batfalcon Europe PT Forum 12 07 Mar 2013 02:53 pm
CLUTCH PEDAL PROBLEM pipjes Tech & Performance Forum 3 05 Dec 2012 05:24 am
PT clutch pedal ass'y 1972cudaguy Classifieds: For Sale/Trade 2 25 Mar 2012 05:12 pm
???Clutch pedal adjustment??? Ctown General PT Cruiser Discussions 5 28 Feb 2005 09:08 pm
