My radio fix, 2003 Limited, worked but no illumination
Like Tree7Likes
  • 3 Post By JimBippy
  • 1 Post By _PTGT03
  • 1 Post By chuzz
  • 1 Post By JimBippy
  • 1 Post By chuzz
Old 04 Dec 2016, 12:13 pm
JimBippy's Avatar
Smile My radio fix, 2003 Limited, worked but no illumination
My symptoms were no display in the on position. Radio, CD and tape functioned all the time but the display would not illuminate while in the run position. In ACC everything worked as it should. I tried the key wiggle, re-grounded the steering column with no results. I cut the purple w/ yellow trace that leads to the data bus and now the radio works in both positions. Time is being kept correctly, memory stations remain programmed. If any adverse affects occur I will post a follow up but this seems to have cured my woes, I tried this after finding a video on YouTube referencing a data link problem on a different model Chrysler radio. Hope this helps someone.
Old 04 Dec 2016, 04:26 pm
_PTGT03's Avatar
Default Re: My radio fix, 2003 Limited, worked but no illumination
great tip
JimBippy likes this.
Old 04 Dec 2016, 05:14 pm
I had the exact same problem and fixed mine with a zip tie around the connector under the steering wheel. The one where the radio plugs in. Simple pimple and been working like that for 5 months now.
Old 04 Dec 2016, 06:10 pm
JimBippy's Avatar
I tried that, I damn near tried everything I could find on the forum. No matter what I did with any of the wires it just wouldn't light up in run. Strangely the switched power at the radio was receiving power with the key so it was getting the correct power from the switch but something in the databus connection just wasn't sending the correct signal. At least I know my dash is well grounded now.
This is the first time since I bought the car it's been illuminated in the run position. WhooHooo!
Handy_Cruiser likes this.
Old 05 Dec 2016, 06:41 am
I had an uncle that once told me if I was going to own Chrysler products (like my dad), that I had better carry around alligator clips, electrical tape and wire cutters, because I'd sure as hell need them! LMAO Uncle Lester has proven to be right over the years.
Instrument Cluster Illumination Sandeee General PT Cruiser Discussions 2 10 Sep 2016 12:20 pm
Passenger Side Sun Visor, with illumination jdocop Classifieds: Want To Buy 1 07 Jan 2016 06:26 pm
2002 limited edition oem radio SabreGrub Classifieds: For Sale/Trade 0 27 Jun 2012 04:43 pm
Replacing switch illumination MM64 Tech & Performance Forum 8 18 Aug 2011 06:34 am
Radio illumination problem Rodville General PT Cruiser Discussions 6 25 May 2008 10:01 pm
