Intake camshaft and Exhaust camshaft
  • 1 Post By rob302
Old 07 Dec 2016, 01:42 am
Default Intake camshaft and Exhaust camshaft
I replaced the head on my 01 pt cruiser and after lining all timing marks up I should be able to manually crank them 2 full turns but it only goes about a 1/4 of a turn and stops. Are the intake camshaft and exhaust camshaft the same size?
Old 07 Dec 2016, 01:48 am
Default Re: Intake camshaft and Exhaust camshaft
Welcome to the forum.
Are all the spark plugs out when you are turning the crank?
Old 07 Dec 2016, 01:53 am
No they are not out but shouldnt I still be able to crank it with them in?
Old 07 Dec 2016, 02:04 am
Thank you for the welcome!!
No, they are not taken out.
Old 07 Dec 2016, 05:29 am
rckstein's Avatar
Old 07 Dec 2016, 10:21 am
Much harder to do so with plugs in. Picks of you marks helps. Also look in the technical section and look for the how to section. In there is a thread called HARMONIC BALANCER TIPS AND TRICKS. I have some great picks of what your into.
Lot of good threads there forever r this and other repaires.
Old 07 Dec 2016, 10:53 am
rob302's Avatar
i believe you should be able to tell where the magnet attaches to the back of the cam(for the cam sensor) to see which one goes where
Old 08 Dec 2016, 10:40 am
To answer your question... Yes, you should be able to turn the engine over by hand as many times as you want to, if nothing is hitting to prevent this. And to repeat someone else's statement, it is easier when the plugs are out.
Camshaft Sensor nickstewartroc Tech & Performance Forum 1 08 Jan 2013 01:19 pm
Camshaft and crankshaft bheffner PT Cruiser Convertible Forum 4 06 Oct 2012 04:40 pm
WANT TO BUY: 2.4L Camshaft Sprocket 76911S Classifieds: Want To Buy 5 06 Aug 2012 10:38 pm
Camshaft sensor (again!) ABrown Tech & Performance Forum 21 29 Mar 2012 03:31 pm
2 different Camshaft sensors??? 66CUDA Tech & Performance Forum 1 16 Jun 2009 10:35 pm
