Dashboard indicators down
  • 1 Post By PtCabriFr
Old 08 Dec 2016, 04:17 pm
Default Dashboard indicators down
Hello and sorry for my english, I might not use the proper mechanical term sometime
I bought a 2005 2.4L PT few months ago and just decided to fix all its problems.
First one: the dashboard!
Has no information on it. Seems go be something very common on this car but I would need your help to give me some links/advices on how to fix this.
A "weird" fact is that my oil gauge is "working", it always says that my tank is full even tought it's empty.
Second thing, once I was drinving on the " réserve" (like few liters left in my tank) my dashboard went on for few minutes, twice! But needles were giving wrong information.
Is it something typical on this dashboard indicator problem?
Thanks for your help!
Old 08 Dec 2016, 04:31 pm
rob302's Avatar
Default Re: Dashboard indicators down
for the fuel gauge stuck on full, check the ground wire in this link: Embarassing question I have to ask because I made a huge error
you want to check ground wire G104. when it is broken, the fuel gauge will be stuck on full
Old 08 Dec 2016, 04:48 pm
Oh, that was unexpected! I'll check this out asap and let you know. So I need to remove my driver side headlight in order to get there?
Old 08 Dec 2016, 05:18 pm
rob302's Avatar
you can check the ground wire near the fuel tank for continuity, or temporarily add another ground at the fuel connector to verify it fixes the problem. if it does i would then remove the light and have at it
Old 24 Dec 2016, 05:51 pm
All wires were ok, I had to replace the cluster.
I bought a used one from a 2.0 PT cruiser and it fits my 2.4l
It was a hard job to remove all the plastic stuff to get to the cluster but it worth it!
rckstein likes this.
All gear indicators on and won't start Mrcapthowdy General PT Cruiser Discussions 1 18 Oct 2016 06:11 pm
Indicators flashing. Why? NLAlston General PT Cruiser Discussions 2 08 Aug 2016 04:05 am
indicators and wipers BogleLodge Tech & Performance Forum 3 28 Dec 2012 03:36 pm
