Lower Intake Manifold
Like Tree3Likes
  • 1 Post By Imakenocents
  • 1 Post By JimBippy
Old 10 Dec 2016, 04:28 pm
JimBippy's Avatar
Default Lower Intake Manifold
I'm planning on replacing my lower intake gaskets tomorrow (Felpro) and want to know if anyone's done it without removing the upper radiator hose? It looks tight but doable. I was planning on removing the FI wiring harness plugs at both ends to remove the fuel rail with the injectors attached to the manifold. I have a set of flow matched rebuilt OEM injectors with new seals I'll be putting back in. Any pitfalls or headaches I should be looking out for? Thanks in advance for any and all help.
A little background, it has a poor idle that improves as the engine warms up, acts just like a vacuum leak. When I changed the plugs and wires (Champion 443s and Denso wires) the upper manifold had the original gaskets with sealer splooshed all over, cleaned it up and put in Felpro seals. I'm hoping the lower seal and injector replacement will end my idle concerns as I can almost hear a cold engine vacuum whistle but can't locate it. Once again thanks everyone.
2003 Limited 2.4L Woody
113,000 (10/2016)
Non-Turbo
Automatic
ABS 4 Wheel Disc (No Traction Control)
Blue LED interior lights
Lived most of its life in SoCal appeared on the East coast at 87,000 miles that's when the Timing belt was done. First owner took immaculate care of it but the last owner just drove it. I'm bringing it back to immaculate.
Old 10 Dec 2016, 06:18 pm
Wink Re: Lower Intake Manifold
In response to your question the following video from the 7 minute mark to the end will demonstrate how to gain more access to the lower intake area and make the job much easier. The man in the video is a mechanic at a Chrysler dealership and he gives great info as well. Hope it helps you out.
JimBippy likes this.
Old 10 Dec 2016, 06:45 pm
JimBippy's Avatar
Default Re: Lower Intake Manifold
Great video, that'll free up lots of room.
Thanks!
113,000 (10/2016)
Non-Turbo
Automatic
Old 11 Dec 2016, 12:25 pm
JimBippy's Avatar
Thanks again, the video really helped out a lot. Jobs done and baby's running nice now! Lower gaskets were originals and pancakes and the injector O rings on the manifold side were dried up and brittle. Scrubbed and cleaned the lower manifold before reassabley, fuel rail is chrome again, it a very good day! This forum is better than any Chiltons I've ever come across! Thanks again.
War_Eagle likes this.
113,000 (10/2016)
Non-Turbo
Automatic
Old 11 Dec 2016, 10:50 pm
Always good to hear successful outcomes!
Cylinder 2 Lower Intake Manifold Discoloration bennyc General PT Cruiser Discussions 16 05 Dec 2016 12:20 pm
looking for composite upper and lower intake manifold Ptworm Classifieds: Want To Buy 7 15 Aug 2016 06:12 pm
Plastic Lower Intake Manifold chris15 Classifieds: Want To Buy 7 13 Feb 2014 07:20 am
looking for lower intake manifold crazyptguy Classifieds: For Sale/Trade 13 29 Feb 2012 08:20 pm
Lower intake manifold elmeyer Tech & Performance Forum 2 09 Sep 2009 08:47 pm
