Error Codes P0E2C, P0E28, C2500
Old 11 Dec 2016, 04:33 am
Exclamation Error Codes P0E2C, P0E28, C2500
Googled 1st 2 Codes Driver Motor Inverter Temp Sensor H Circuit (Intermittent/Erratic)
P0A00 – P1999 Codes | Think Systems Diagnostics
(hold ctrl F find function )
Is this Correct has any else gotten this Error Code?
Where can I Buy the Sensor Autozone, Advanced Ebay; Or can I clean and replace the sensor?
How do I change it, where is it on the PT?
2nd Code C2500
C2500 Engine Code Meaning - C2500 Engine Trouble Code - How To Fix C2500 | EngineCodes.net
Is this 5=BBV Sensor Circuit Low Voltage
0=Low Coolant Circuit
0= Park/ Neutral Posiyion PNP Switch Circuit
OR
Engine Torque Signal Circuit
C2500 Car Error Code , C2500 Engine Trouble Code Solution | CarErrorCode.com
Fuel Composition Sensor Circuit Malfunction
Cylinder Injector Circuit Low
Crankshaft Position Sensor B Circuit Malfunction
These are pending codes.
Are their any suggestion on how to trouble shoot each and how?
I'm going to change the oil & filter; Spark Plugs and wires, and engine coolant and change transmission fluid?
Any suggestion would be greatly appreciated!
Thanks, Happy Holidays, Merry Christmas and God Bless You for your help!,
Ben
Old 11 Dec 2016, 08:37 am
Default Re: Error Codes P0E2C, P0E28, C2500
Ben, welcome to the forum.
Can I ask where you retrieved those error codes from? They aren't the codes that should come up using a scanner or key trick. a mechanic once told me codes that come up like the ones your showing aren't meant to show trouble but are codes especially designed for engineers or dealers.
Below is a list of codes that can help you diagnose PT related faults. Use a scanner or follow the instructions on the top of the list with your key in the ignition to try and pull others codes on the list.
Error Codes
How to retrieve fault codes.
Also, please log onto the WELCOME section of the forum to tell us about yourself and your PT Cruiser. Info about your cruiser (year, mileage. problems your having and what have you done so far as to solve those problems) can help US help YOU.
Old 11 Dec 2016, 08:52 am
Welcome to the forum. I've never seen any of those codes.
Ignorance can be educated, crazy can be medicated, but there IS no cure for stupid.
Old 11 Dec 2016, 09:44 am
I found this from PT Do-It-Yourself.net about the odd codes.
The theory is that the codes are the software revision level of the cluster, not MIL codes. We cannot confirm this theory, but it makes sense.
MIL = Malfunction Indicator Light
Old 11 Dec 2016, 01:05 pm
2nd Code C2500
OR
Ben
How do you know the websites you have chosen to interpret your codes are manufacture PT Cruiser specific?
Tags
c2500, error codes, p0e28, p0e2c
4 error codes... HELP! Lacemw Tech & Performance Forum 6 25 Jul 2014 02:20 pm
what these error codes really mean? ManMartin General PT Cruiser Discussions 5 18 Jul 2013 03:55 pm
Error Codes Error lilcruiser Tech & Performance Forum 2 10 May 2012 05:34 am
ERROR CODES Kirby General PT Cruiser Discussions 4 24 Oct 2006 03:15 am
