Replaced PCMs are not working
Like Tree14Likes
Old 16 Dec 2016, 01:16 pm
Default Replaced PCMs are not working
Our 2004 PT cruiser 2.4L broke down, would not start anymore, just crank. Mechanic replaced battery, starter, alternator, then the car ran, but would not charge battery. Mechanic told me car needs new PCM. I ordered new PCM module, car started once, puttered unresponsively, and stalled. From then on, it would not even crank anymore. I put in the old PCM, it would not crank. I jumped the starter relay, the starter works. Incidentally, both the old and the new PCM can not be read by my scanner. I returned the rebuilt PCM and got a other one, still the same symptoms: No cranking, no readout with scanner. Also, the keydance does not work for codes readout. It is as if there is no power to the PCM. Did anybody else experience similar problems? Any idea what I have overlooked. The fuses seem OK, in cabin and under hood. I am clueless.
Old 16 Dec 2016, 01:53 pm
Default Re: Replaced PCMs are not working
Welcome to the forum
WELCOME and Forum Rules
We encourage all new members to say hello and introduce yourself to the rest of the community by starting a post in the Welcome New PT Owners thread at the top half of the forum.
Old 16 Dec 2016, 10:41 pm
check the number 13 fuse under the hood didnt blow thats the asd/fuel pump fuse runs all that
rckstein likes this.
Old 16 Dec 2016, 11:47 pm
Smile Re: Replaced PCMs are not working
scoobysnacks420, you are the man !!!! or woman !!! Fuse was blown, and I thought I checked it. Car finally starts up, runs nicely, BUT: battery not charging . Aaaahhh,
That was the reason I put in a new PCM(s) to start with. I was told the charging does not work due to a defective PCM. SO: I am back on square 1, but definitely away from square minus 4. Haha..
Thanks a lot Scoobysnacks420. Wonder if you (or someone else) have another ace up your sleeve.
Alternator is new, starter is new, just the charging does not work !!! Another funny fuse I did nor check ....
Old 17 Dec 2016, 01:04 am
_PTGT03's Avatar
The non-charging can be simply due to an open in the signal or ground going to the alternator harness connector. Does your battery light come on ? What is voltage at idle. It is highly unlikely to be the PCM after the same symptom appears across two replacement units.
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 17 Dec 2016, 05:22 am
rckstein's Avatar
Old 17 Dec 2016, 07:32 am
SPLNeon's Avatar
Not sure if the pt has a fuesable link from alt, but the Neon of the early years would often have problems with that wire and replacement would solve the issue. Its just a guess as ive pulled more wires from a pt then actually diagnosing any electrical gremlins lol.
I know how to test this theory, but am not going to post how, as things can go bad, and i dont want blame for any misshaps.
THE UNDISPUTED KING OF THE PARKING LOT
Competition's paying the price.
03 PT GT. DSI canned tune, Weight redux, MH Racemaster Slicks/Rota Slipstream 15" 11.95 at 118.41mph 1/4 mile
96 SOHC Neon Turbo
08 CSRT4. Realtune MS1K v1 pcm stg0 NSRT4 Injectors.
Old 17 Dec 2016, 07:36 am
Where did the replacement alternator come from? I worked for both Autozone and Advance in the past and had alternators from both places test bad, right off the shelf. I made it a policy to bench test every alternator I sold before I'd let a customer leave with it. I had fewer returns, but even then, sometimes they'd come back defective because bench testing isn't the same as load testing one in the car. Take it and have it load tested IN THE CAR.
Ignorance can be educated, crazy can be medicated, but there IS no cure for stupid.
Old 17 Dec 2016, 11:46 am
Excellent question. Got the car towed to a Firstone place, and they were pretty helpful. After installing new battery and starter, they replaced the alternator. Car now started, but no charging of the battery, so they put in a second alternator (2.5 hours each time, I think it is somewhat tricky to change the alt). So, they initially also suspected a bad alternator from the shelf , but discarded the theory after the second one did not charge the battery either. (They charged me only for one alt)
That is how they came up this the PCM theory. They said they measured some voltage at the PCM connector and that was off, hence the computer must be bad.
I have no idea where Firestone buys the parts, I know it is aftermarket in most cases.
Long story short:
Car refuses to start, some "weird blinking" of "all lights" (daughter)
New battery
new starter
new alternator
another new alternator
Result: Now car starts, but won't charge
new PCM
another new PCM
Result: Car starts, but won't charge
No codes in computer, battery voltage 11.8 Volts with engine off, voltage 11.2 Volts with engine on. Battery lamp NOT on initially, but will come on as soon as headlights are switched on or you drive around the block.
Old 17 Dec 2016, 12:40 pm
LionPT's Avatar
Has anybody checked the plug & wires from the alternator..??
A few users have posted that they found a broken wire leading from the alternator.
A/C not working after timing belt replaced 1gr8pt Tech & Performance Forum 11 31 Jul 2015 09:30 am
Replaced almost everything. Really need help Nealpeters General PT Cruiser Discussions 8 24 Apr 2015 07:34 pm
05 Touring turn signals working & not working angel66rose Tech & Performance Forum 5 11 Dec 2013 09:34 am
IOD fuse replaced and still not working sometimes rafysonera General PT Cruiser Discussions 2 12 Apr 2013 01:31 pm
2006 - Replaced Fan - Comperssor Not Working wbwalsh General PT Cruiser Discussions 5 23 Jul 2009 02:33 pm
