Help Please
Old 21 Dec 2016, 10:52 am
Question Help Please
Hi all,
I have a 2002 Woody, it has recently started doing something really odd, there's no error codes and my mechanic has no idea because of course I can't replicate it.
It will cold start fine, then I can drive it any distance with no issue. If I turn it off and then get back in relatively quick it will start again. However after about an hour it's completely dead. No lights nothing. Then if I wait another 2 or so hours it starts right up again.
Does anyone have any ideas?
Old 21 Dec 2016, 10:53 am
Default Re: Help Please
Welcome to the forum
Old 21 Dec 2016, 10:55 am
Thanks NitroPt!!
Old 21 Dec 2016, 10:59 am
There are lots of threads about poor or problematic drivibilty and no start issues over more than a decade of information to be found here.
Welcome New PT Cruiser Members - PT Cruiser Forum
We encourage all new members to say hello and introduce yourself to the rest of the community by starting a post in the Welcome New PT Owners thread at the top half of the forum.
First idea is seek a "real" trained auto mechanic! Or even better an ASE Auto Technician
Next have the battery load tested and while there check all the connection look carefully at grounds.
Then check the diagnostic connector for those codes your "mechanic" claimed were not there. They are there...trust me unless your PCM is faulty or the connector is damaged!
Old 21 Dec 2016, 12:22 pm
As NitroPT says this requires a good mechanic. The link below gives you three possible different common issues that might be causing your issue. There are many other causes that can have the same symptoms. As suggested first go to a auto parts store where they will hook up their scanner and tell you for free what codes you might have. Post back what you find out. If you want to try and do a diagnosis yourself we can help you every step of the way.
2005 PT Cruiser won't start -- wait two hours and starts fine
Old 21 Dec 2016, 12:42 pm
VsandFords's Avatar
Welcome to the forum from Texas.
Old 21 Dec 2016, 01:44 pm
rckstein's Avatar
