Came to a stop sign the car suddenly sputtered and that is where she stayed! HELP!
Old 25 Dec 2016, 11:57 am
Default Came to a stop sign the car suddenly sputtered and that is where she stayed! HELP!
So i pulled up to a stop sign. and all of a sudden she sputtered and died. Killed the battery trying to start it again. Each time i tried to start it she would turn over and sputter for a second or less and die. I got her home and put another battery to it and used starting fluid down the throttle body and she would run. shes a 2008 base model with 130,000 miles. how can i tell if its the fuel pump or the computer? Any help would be appreciated. Happy Holidays!
Old 25 Dec 2016, 12:44 pm
Default Re: Came to a stop sign the car suddenly sputtered and that is where she stayed! HELP
Looks like you have answered your own question, its not getting fuel. Check for blown fuse, Check for ground and 12 volt at the pump which has 4 wires, two for the fuel gauge and 2 for the pump. I just changed my pump, hard starting.... Check to see if you hear the pump running for a few seconds when you turn the key to ignition, Or check for pressure... I lift the rear seats, cut a 3 sided hole in the carpet and floor, disconnect power, fuel line, .... Replace pump.... no need to drop tank.
If you ar not versed in tools needed you could get burnt by causing spark with steel tools.... You could pick up a used fuel pump for a late model cheap.. at recycle yard if needed.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 25 Dec 2016, 02:16 pm
Nice. Thank you. Where can i get access to the wires without pulling out tank? Any color codes to the wires? What would be the best way to cut a 3 sided hole without pulling the tank? Pump definitely is not "whirring." Thank you!
Old 25 Dec 2016, 03:02 pm
Before you attempt to get access to the fuel pump I would suggest finding which wires go to the fuel pump first.
On the PT Cruisers that are manufactured in 2006 and up the fuel pump is controlled by the TIPM. I would suggest doing a battery load test to make sure the voltage is not dropping. The TIPM is sensitive to voltage drops.
On 2008 PT Cruisers they are not equipped with a fuel pump relay. The fuel pump control is done through the TIPM. The TIPM receives an input signal from the PCM. Once the TIPM receives the signal, it will output a 12 volt supply to the fuel pump module turning the pump on.
I would suggest applying a 12 volt feed directly to the fuel pump to see if the fuel pump is working properly. If it does work properly then you need to find out if the TIPM is faulty causing the fuel pump not to run. Verify you are getting 58 +/- 5 PSI if the fuel pump starts to run with the manual 12 volt feed.
The link below had a member that had the TIPM causing the fuel pump not to work properly.
Fuel pump relay
This is what the TIPM looks like.
Old 25 Dec 2016, 05:26 pm
Thank you again. Pump is bad and needs to be changed. I got the pump and i just cant figure out how to disconnect the fuel line. got the electrical connector off just can't get the fuel line off.
Old 25 Dec 2016, 09:08 pm
I would not remove the gas connection until you get rid of all the dirt on to f the pump.. Blow it off-- wash it off ..but you must clean it first.
To remove the gas line just push in on the black keeper near the end of the fitting whil gently pulling the gas line. Wip up any spilled gas....... PLEASE
You may want to check for power first as there have been ground problems, with out ground to the pump it will not work even if you have 12 volts to a body ground.
73 Charger SE
01 Sebring flip
Old 26 Dec 2016, 12:16 am
[QUOTE=JoeX;636164]
Could you explain that please?
2008, base 4 door, 2.4 NA, Automatic, Silver, 77,000 miles, very clean.
Old 26 Dec 2016, 02:47 am
[QUOTE=tourhar;636194]
Using steel tools hammer -punch- can cause a spark and if your not careful with spilled gas a fire.
Even static could cause enough spark to care a fire.
73 Charger SE
01 Sebring flip
pt suddenly stops dadzilla Tech & Performance Forum 22 21 Sep 2016 09:10 am
Suddenly won't start jdege General PT Cruiser Discussions 7 06 Jan 2012 06:50 pm
Cruiser Hesitates at Stop Light/Sign caballero77 Tech & Performance Forum 34 06 Oct 2011 12:06 pm
'06 sputtered out and won't start FrankieSixxxgun Tech & Performance Forum 10 12 Jul 2009 05:36 pm
Suddenly - no fresh air Red Octopus General PT Cruiser Discussions 5 21 Mar 2007 09:37 pm
