2001 5 speed issue
Like Tree3Likes
Old 25 Dec 2016, 07:01 pm
Default 2001 5 speed issue
I am new to the forum, great site. Have a 2001 5 speed. I am having an issue with the car jerking/stuttering when accelerating from a stop.
There are no codes.
I have replaced all the injectors, injector connectors, Plugs (gapped correctly,.40), plug wires, coil, PCM. There are no air leaks. I have removed and cleaned the throttle body and IAC.
The car will start and idle perfectly but stutters and stumbles when pulling off. I suspect the TPS or Cam sensor but since there are no codes I am hesitant.
Can anyone offer any advice?
Old 25 Dec 2016, 07:30 pm
rckstein's Avatar
Default Re: 2001 5 speed issue
Welcome to the forum
Old 26 Dec 2016, 12:47 pm
Really?... Nothing?
Old 26 Dec 2016, 01:06 pm
rob302's Avatar
you might test the TPS with a multimeter set to 0-20vdc to check for "dead spots". ie: stabbing the middle (or/db) wire and the black wire with a multimeter. key on engine off while you do it. probe the wires and then open/close the TB slowly and make sure the voltage changes smoothly and does not spike or drop. you might remove the cam sensor, make sure the magnet on the end of the cam is clean and not cracked, and then gently reinstall it.
likely the lack of responses is because you are having a very uncommon issue and anything we recommend you do might just end up at 3-4 pages of you wasting time and money testing and replacing stuff with no change, or even making it worse. when my car does something like you describe, i normally let it get worse in hopes it trips a code or the problem becomes more obvious as to what to fix.
Old 26 Dec 2016, 02:31 pm
I have minimal knowledge or experience with manual shifts. Every one that I ever owned was great. Except the piece of crap in my 84 Laser XE. That transmission was trouble from day one.
Ignorance can be educated, crazy can be medicated, but there IS no cure for stupid.
Old 26 Dec 2016, 08:57 pm
Replaced the TPS, no change. The one strange thing I noticed is that it does not stutter and jerk when backing up. It pulls smooth and powerful. ONLY going forward.
Any other ideas are appreciated.
Old 26 Dec 2016, 10:02 pm
The 2001 & 2002 PT Cruisers are known for the wire harness from the crankshaft sensor to drop down on the half shaft after the harness clamp breaks. The wires may only be touching the half shaft when the PT Cruiser moves forward. Check the wire harness by getting underneath the engine.
Old 27 Dec 2016, 12:02 am
Fil Fil is offline
I am new to forum my 2001 cruiser cut out while driving three times in the past couple weeks the first two cut outs were easy re starts the third took some time turning the motor over when finally started it got me home. the car sat for two days when I went to drive it motor just turn over wouldn't fire up so I left it. Two days later I went back to it again same problem (I can here fuel pump working) then it fire up idol okay so I brough the revs up could feel the motor starving for fuel and it cut out it re started okay turn ignition off and left it. Went out today and motor just turning over wouldn't fire up do you think the problem is fuel filter ?
Old 27 Dec 2016, 01:58 am
DroptopPTGTCruizer's Avatar
Originally Posted by Fil View Post
I a new to forum my 2001 cruiser cut out while driving three times in the past couple weeks the first two cut outs were easy re starts the third took some time turning the motor over when finally started it got me home. the car sat for two days when I went to drive it motor just turn over wouldn't fire up so I left it. Two days later I went back to it again same problem (I can here fuel pump working) then it fire up idol okay so I brough the revs up could feel the motor starving for fuel and it cut out it re started okay turn ignition off and left it. Went out today and motor just turning over wouldn't fire up do you think the problem is fuel filter ?
Welcome to the forum. Being new, couple of things, when having an issue w/your PT, start a new thread, don't just drop your issues in on another members already started topic thread, not only will you not be likely to get an answer, it's just good etiquette. Also provide more info then just yr of your car, auto or manual trans, miles, etc. If you read the "Welcome new cruiser members" section, you will find this & other helpful tips. Cheers!!
WELCOME and Forum Rules
2005 PT GT Convertible HO Turbo Autostick ~ black/black leather ~ 53,000 miles ~ summer-only driver ~ OEM rear sway bar ~ K&N 57 series CAI ~ 4-wheel ABS ~ Hawk Sector 27 drilled/slotted rotors ~ Hawk Performance Ceramic pads ~ Firestone Firehawk Indy 500 Wide-Oval performance tires ~
Old 27 Dec 2016, 02:13 am
There are no codes.
2001 pt 2.4 engine 5 speed abettiga General PT Cruiser Discussions 6 22 Aug 2015 11:46 am
engine swap 2001 pt limited 5 speed jake69shelby Tech & Performance Forum 1 27 Oct 2014 12:26 pm
car issue on 2004 pt 5 speed GT version echillie1 Testing 1 28 Nov 2011 10:35 pm
sluggish 2001 5-Speed njred Tech & Performance Forum 12 21 Aug 2007 06:57 pm
2001 PT 5-Speed Shifter Calbe dgalekov General PT Cruiser Discussions 3 04 Jul 2007 05:26 pm
