Oil light again...
Like Tree7Likes
Old 26 Dec 2016, 10:02 am
Question Oil light again...
Hello all,
I have an 07 base model and as some of you may remember, I had my oil light come on a month ago during Thanksgiving weekend. I ended up having AAA tow it to my regular mechanic who has been working on the family cars for years now. They ended up changing the oil but it didn't the problem and then they changed the oil sending unit. That ended up fixing the problem... until last night when the light came back on and the car has oil. Could it be the sending unit going bad again or could it possibly be something else?
2007 Base model in Cool Vanilla 145,000+ miles
My mods: LED headlights and a K&N Intake
Old 26 Dec 2016, 11:12 am
rob302's Avatar
Default Re: Oil light again...
i would blame the sending unit or the connector/wire attached to it. i'd call the people that fixed it. you've been using them for service for years and i would doubt they'll give you any trouble about it.
Old 26 Dec 2016, 11:32 am
rckstein's Avatar
Can you find out what brand of sending unit your mechanic installed?
Old 26 Dec 2016, 12:01 pm
Wink Re: Oil light again...
Originally Posted by smittey5656 View Post
Hello all,
I think you should get an actual oil pressure gauge reading by connecting directly to the engine either done by yourself or your mechanic. Considering your mileage that's the route I would go just for peace of mind knowing the actual oil psi, particularly at engine idle. Then compare that reading to specification.
Old 26 Dec 2016, 12:11 pm
This is common (Re:" Oil light again"...)when the oil sensor is replaced and the connectors are not thoroughly cleaned on a PT Cruiser. You may simply need to remove it clean it and reinstall it. Brand has absolutely NOTHING to do with it!! As it has already been mentioned to be working for several hundred miles. Keep in mind that it is easy to damge a any sendor or sensor during installation which may not be apparent for many months or miles.
Also check for engine codes using a scanning tool at the diagnostic connector. Note and than clear them recheck after a day or so. If you are having a shop check them than drive for about a 1/2 and return to the shop for a recheck.
I have been through this with a few(many) members on this forum. I would not spend the money on another one until you first do that.
It is not necessary to check the oil pressure manually on a Chrysler 2.4. When the pump fails you will know it. Tic, tic, tic, ticing away on the top end components. The oil pump is very well designed and seldom fails or for that matter wears out.
The oil goes from the pump directly to the top end (head) valve train components first and than to the lower engine reciprocating assembly.
The real exception (within reason)to this would be if you recently damaged your sump.....
or of routinely driven 10's of thousands of miles between oil changes.
VsandFords, chuzz and Carnut like this.
Old 26 Dec 2016, 12:23 pm
My oil light would come on and I found If I turned the key to on then off then started the car it would act normal. No light.
Only in America.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 26 Dec 2016, 12:55 pm
Only in America.
This report ^^^^ is also not uncommon...
That is a indication of a dirty connector and/or a sensor damaged or beginning to fail.
In the extreme or at least to note the health and connect-ability of the PCM.
Old 26 Dec 2016, 01:27 pm
Thank you everyone so far on your input, I will call them tomorrow once they reopen after the holiday to give them the suggestions so far. I appreciate all the information Everyone is willing to give!!
Old 27 Dec 2016, 04:04 pm
Just got off the phone with the Shop and they found that the part was defective and ordered a genuine chrysler to replace it. They also found that my radiator cap was leaking so they replaced that as well and I will be getting it back tomorrow.
Old 27 Dec 2016, 04:51 pm
rckstein's Avatar
Just curious, did they tell you what brand of sending unit they installed the first time?
ABS Light, Parking Brake Light, Traction Control Light kupothechocobo General PT Cruiser Discussions 9 28 Feb 2017 01:56 pm
Left Side Break Light / Blinker / Reverse Light MaxJoseph Tech & Performance Forum 6 07 Nov 2015 05:18 pm
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Mork's Tail Light and Reverse Light Tint Progress Morkeste Exterior Accessories Forum 30 23 Jun 2011 12:20 pm
