The cranks but doesn't start!!!
Like Tree2Likes
  • 1 Post By LionPT
  • 1 Post By Imakenocents
Old 01 Jan 2017, 05:43 pm
Default The cranks but doesn't start!!!
So I have an 02 pt cruiser it cranks but doesn't start! So we bought it it ran...But overheated we took it apart changed radiator cap and thermostat and then we saw the head gasket was blown! We changed it put it all back together now it won't start! Since then we changed the spark plugs, got a new battery, spark plug wires, camshaft position sensor, coil pack, and the crankshaft position sensor! Still cranks and won't start!, Fuel pressure is good! Fuel pump works...Can't figure this damn thing out!! Everything is hooked up!! Any suggestions I'm willing to try anything at this point!, Please and thanks you!!
Old 01 Jan 2017, 05:45 pm
rckstein's Avatar
Default Re: The cranks but doesn't start!!!
Welcome to the forum
Old 01 Jan 2017, 06:22 pm
LionPT's Avatar
Switch the coil & camshaft sensor plugs...the plugs are the same & users mix the 2 up when putting things back together.
Old 01 Jan 2017, 06:50 pm
VsandFords's Avatar
Welcome to the forum.
What about the timing/timing belt? Is everything lined up correctly?
Old 01 Jan 2017, 06:55 pm
If the coil & camshaft sensor plugs are in the proper connections I would suggest checking to see if you have spark on all 4 cylinders.
Harbor Freight sells a spark test for a reasonable price.
http://www.harborfreight.com/catalog...q=spark+tester
If you have spark I would suggest putting some starter fluid in the throttle body to see if it starts to run.
Old 01 Jan 2017, 08:54 pm
Wink Re: The cranks but doesn't start!!!
Sorry to hear about your situation but don't lose hope you can get it figured out. I would suggest chances are very high something in your reassembly went back together incorrectly. We know that before the head gasket change the car would run but now does not. It is not likely a component that you previously removed just up and failed by removing it. It is possible but I would say those possibilities are very slim. Now the swapping of the connectors previously mentioned by other members is a definite possibility. Also thoroughly check all your connections in and around the throttle body, that's a busy area with many connections in close proximity. Check all of your vacuum line connections as well. The timing belt alignment is critical on this engine and can't be looked at with a close enough mentality, it must be dead on. You have verified your fuel pressure, as has been mentioned check for spark. Make sure the map sensor on the upper intake is connected and the TPS and IAC over by the throttle body. Basically just retrace your steps and I believe you will discover your no start problem. That timing belt alignment is highly suspect and I can't emphasize enough how important that step is to the proper operation of the engine after reassembly. Just keep in mind it ran before you started your repairs and now does not, highly unlikely to be a component failure but more likely user induced failure and I say that kindly, I've been there through the years.
VsandFords likes this.
Old 01 Jan 2017, 09:38 pm
One other item, double check your spark plug wiring from the coil pack and ensure the wires are connected to the proper corresponding cylinders.
Cranks but no start? C300392 Tech & Performance Forum 4 15 Apr 2016 07:58 am
Cranks, won't start (bad PCM ???) dxv77 General PT Cruiser Discussions 14 26 Jul 2015 05:19 pm
starter cranks but motor doesn't turn over aries666 Tech & Performance Forum 1 23 Apr 2015 07:39 pm
05 PT cranks but won't start. Noah1 Tech & Performance Forum 5 22 Jan 2015 03:38 am
Cranks but want start stickkman99 General PT Cruiser Discussions 8 04 Aug 2013 12:00 am
