miss in idle
Like Tree6Likes
Old 02 Jan 2017, 04:00 pm
Default miss in idle
my 2003 turbo has bad shake when in gear both reverse & drive it is running sittng in the garage put from nutral to drive bad shake but it stops when taken out of gear i don't feel anything my seat is now smooth drop in down to drive bad shake .
.only code 0440 probably cap if i put in new cap it throws a 410 an did
this will not cause a bad iddle when in drive what are some of the things to check
ok i found that plugs and wiring might be the answer will update if this is it
ok shake now after new plugs well i can tell there is little shake not much in the that i can feel
but the shake in the air cond. it is bad the shake at idle in gear
i seen a video on utube on tighteing the mounts any pointers now would be handy thanks
VsandFords likes this.
Old 02 Jan 2017, 05:05 pm
Default Re: miss in idle
Yeah, if the plugs and wires don't help that much, take a look at your motor mounts.
Ignorance can be educated, crazy can be medicated, but there IS no cure for stupid.
Old 03 Jan 2017, 05:18 pm
And look at the torque struts.
2008, base 4 door, 2.4 NA, Automatic, Silver, 77,000 miles, very clean.
Old 03 Jan 2017, 05:29 pm
bosh platinum 5711 were the new plugs
prostart ch74210sp were the wiring these were the things i have done
i just replaced the pcv valve so i know it not that
i sprayed the every thing related to air trying to find a drop in engine idle
it all goes backed to the plugs maybe that what the girl was using but what im thinking is re14mcc5 plugs maybe going back to what the mfg. sajested that will be the next thing you mention the motor mounts i replaced both whe non the passenger side i tried to tighten the motor mounts i know there is three
i need to take a trip with this idle problems do you think the pt will make it i guess i could tell you new timing belt water censor change th tranny filter all the codes have been fixed but the 440 gas cap
hows anybody running mid grade in there turbo
Old 03 Jan 2017, 07:29 pm
Was the upper and lower motor mounts adjusted per the factory manual? If not let us know and we can post some information on how to adjust the mounts.
Old 04 Jan 2017, 06:58 am
Every time I see a post on rough idle I need to read it. I too have it, lots of nice folks on here with professional skills have tried to help. I too have done the spray trick around the plenum to block area. But no help. PCV changed, etc, new plugs, wires, no coil yet although it has a new one when the exhaust valve cooked. I have no codes. Mine smooths out above idle but I suffer from a what a mechanic friend told me he thinks might be a lean condition as I do get some light pinging. One thing he mentioned which I have failed to check as its winter here in New England and last thing I want to do is work on a car outside. Anyway, he advised to check the injector o rings! Hmmm, never thought those could be leaking, or a crack in the plenum some place, arghhh I hope not.
Old 04 Jan 2017, 07:20 am
Roadmap, part of YOUR miss is most likely the crappy Bosch plugs you have in it. Mopar uses Champion plugs for a reason. Their engines perform better with them! Get rid of the Bosch and get the proper Champion copper core plugs for your PT. Change them every 30,000 miles. I don't know the proper # for the ones you need, but someone here will if your local parts store can't tell you.
Old 04 Jan 2017, 12:36 pm
_PTGT03's Avatar
Advice adding a quart of acetone into the fuel as an injector cleaner and running through a can of mopar intake spray cleaner
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 04 Jan 2017, 09:45 pm
Using acetone is a bad idea. When are you going to give us approved data that says this is a safe method on the PT Cruisers?
Acetone is known to deteriorate cheap plastics and other substances. While the components in a car's fuel system should be of high quality, and thus immune to any deleterious effects from exposure to acetone, be aware that "ideal" is not always the case in practice. Be advised that not all systems have been tested against acetone. Until such thorough testing has been accomplished and certified by an accredited authority, you assume your own liability for experimentally testing acetone in your particular system.
As I said before I would suggest not giving out this advice anymore.
L2fish likes this.
Old 04 Jan 2017, 10:36 pm
We use acetone at work to melt plastic together.
OFF IDLE MISS WITH OCCASIONAL BACKFIRE Jdhaulr1 General Turbo Discussions 46 29 Sep 2016 11:41 pm
intermittent miss at idle... luvtofish Tech & Performance Forum 9 23 May 2012 06:25 pm
Slight miss above idle tburrey General Turbo Discussions 1 11 May 2012 09:13 pm
Miss at idle when starting cold?? mjb457 Tech & Performance Forum 1 14 Jun 2007 09:46 am
idle miss and boost surge mtnbktrek General Turbo Discussions 7 02 Feb 2007 04:08 pm
