Fan questions??
Like Tree9Likes
Old 04 Jan 2017, 01:36 pm
Default Fan questions??
got a few questions about the fan on my 06
1.does the car have to be up to running temp for the high speed fan to kick in when you turn on the AC? or will the fan kick on in AC mode even if its not warmed up?
2.If the low speed fan is not working and the AC is not on will the high speed fan kick in if it starts to get hot? or is it just for when running the AC?
3.when should the low speed fan come on ?
4.in other words will the high speed fan come on if the low speeds not working when it starts getting hot?..
Old 04 Jan 2017, 01:42 pm
LionPT's Avatar
Default Re: Fan questions??
Old 04 Jan 2017, 09:11 pm
Just in case you have trouble with the chart when you start the engine cold, turn on the A/C. the radiator fan should come on almost immediately.
Old 04 Jan 2017, 09:25 pm
rckstein's Avatar
Originally Posted by LionPT View Post
Is this chart the same for the Gen1 and Gen2?
Old 04 Jan 2017, 09:28 pm
rckstein's Avatar
Originally Posted by ptcruisersteve View Post
Just in case you have trouble with the chart when you start the engine cold, turn on the A/C. the low speed on the radiator fan should come on almost immediately.
According to the chart provided by LionPT, wouldn't that be the High speed would come on with a cold engine (180 degrees F) when you turn on the A/C?
Old 04 Jan 2017, 10:41 pm
I really don't see anything in that chart that will let either fan speed come on "immediately".... Until "something" reaches at least 180 degrees. And it doesn't tell you whether it is engine temperature or condenser temperature.
2008, base 4 door, 2.4 NA, Automatic, Silver, 77,000 miles, very clean.
Old 04 Jan 2017, 10:47 pm
rckstein's Avatar
On my PT, on a cold engine, and I turn on the A/C, the fan comes on immediately. I have a UltraGauge that monitors engine temp.Tomorrow morning when I first start my car, I will be sure to note the cold engine temp.
Old 04 Jan 2017, 10:51 pm
That's what I thought you or others explained to me when I was trying to troubleshoot my fan/AC problem. And that's the way it is working now after I replaced the fan and relays> Now, I look at that chart and "say what?".
LionPT...Where did this chart come from?
Old 04 Jan 2017, 11:08 pm
rckstein's Avatar
Here is a different chart that seems to explain how the fan on my PT operates:
Old 04 Jan 2017, 11:22 pm
It is very common for the low speed circuit to fail inside the radiator fan motor. When the A/C compressor come on, the low speed is energized by the PCM.
Best way to check the radiator fan is to manually apply 12 volts to the radiator fan plug contacts with the plug unplugged.
HID Questions PTVibe Exterior Accessories Forum 6 26 Dec 2012 05:27 pm
Want another PT - few questions tlturbo General PT Cruiser Discussions 9 15 Sep 2012 07:42 pm
2 more questions..noobe questions.. BarbieCar General Turbo Discussions 9 20 May 2012 07:32 pm
Questions Questions..newbie DaShado PT Cruiser Convertible Forum 0 01 Apr 2006 12:22 am
Ok I will try here. LED questions jmack General PT Cruiser Discussions 2 29 Mar 2005 02:54 pm
