HELP NEEDED PLEASE!!
Old 05 Jan 2017, 04:49 am
Default HELP NEEDED PLEASE!!
Hello, my name is Emma and I really need someone's help with my very loved PT Cruiser!
I am struggling to find anyone who knows much about PT's and I am a little unsure if what I am being told is correct as the garage has not got much experience in PT's
I am filling up the water container and the car runs perfectly, I have been told its the head gasket that needs replacing and am looking at around 1,000 - 1,400 to have it replaced. Could this be something less simple like a leak somewhere? I am also being told that they could strip the engine down and then still not be able to repair it if its damaged the engine but I would then have to pay the 3-4 hours labour charges!
I would welcome and feedback or advice!
Thank you!
Old 05 Jan 2017, 07:22 am
rckstein's Avatar
Default Re: HELP NEEDED PLEASE!!
Welcome to the forum
Old 05 Jan 2017, 10:20 am
Welcome to the forum.
How did the mechanic verify that your PT Cruiser needs a head gasket?
Did the PT Cruiser overheat?
Was a coolant pressure test done to verify no engine coolant leaks?
Does it overheat at high speeds as well as low speeds?
With the engine cold, you start the engine, turn on the A/C. does the radiator fan come on immediately?
Old 05 Jan 2017, 10:22 am
Handy_Cruiser's Avatar
Hi Emma! And welcome to the forum from the great sovereign state of Arkansas!
Head gasket failure is fairly common on PT Cruisers. The cause is that the engine initially overheats for some other reason such as loss of coolant or radiator fan failure which is very common. The initial overheating causes the cylinder head to expand at a different rate than the engine block. Coupled with heat, the expansion causes movement that spoils the head gasket and causes failure.
Symptoms of a failed or "blown" head gasket often include periodic or frequent overheating of the engine. This is often caused by compressed gas in one or more cylinders escaping past the failed head gasket and entering the area inside the engine where the coolant circulates. This gas then forces the coolant out of the engine and the engine overheats. There may also be a leak of coolant down the side of the engine block that comes from between the cylinder head and engine block where the head gasket has failed. But this is more rare.
Your mechanic should have used one or more techniques to determine if the head gasket has failed. He or she may have conducted an engine pressure test and/or chemically tested the coolant for combustion gas. The mechanic may have instead simply observed that after starting the engine (when the engine is cold), coolant soon begins to be ejected from the radiator and overfill the reservoir before the engine overheats.
If you are unsure of your mechanic's diagnosis, you should ask the mechanic how he or she determined that the gasket has failed. True professionals are usually happy to explain their methods and it helps educate their customers as well. But if the mechanic cannot clearly explain the method diagnosis, it may be time to take your PT to a different mechanic.
In many cases, repair of the failed head gasket involves removing the cylinder head and placement of a new head gasket. Many mechanics and "do-it-yourselfers" often also insist on having the head rebuilt at a machine shop while it is off the engine. This helps assure the overheating did not warp or crack the head. Rebuilding the head also includes resurfacing the valves and it helps assure other components in the head will function as they should.
Specific to the PT Cruiser, removal of the head from the engine involves removal of the timing belt and other various components from the side of the engine. This increases the time required and the labor cost for the work. In most cases, the timing belt and other timing components (idler, tensioner, water pump) are changes at the same time since replacement of these is required every hundred thousand miles. If these components are not near one hundred thousand miles, replacement is not required. But the mechanic may ask if you want them changed since much of the labor to do that job is also required for head gasket replacement.
Also, in the majority of the cases, proper replacement of the head gasket as described will solve the problem. The potential for lower engine component damaged is small, but it will increase if the engine continues to be operated and overheats multiple times and/or if the engine is not repaired promptly. Allowing an engine with a failed head gasket to sit unrepaired may allow coolant to leak into the cylinders and eventually corrode lower engine parts. Once leaked into the lower engine, coolant may also displace motor oil and allow bearings and cylinder walls to become scored and damaged when the engine is started.
Again, a professional mechanic should be able to explain all of this to a customer in clear terms. If he or she cannot, it may indicate a lack of skill and/or voracity.
Tags
gasket, head, leak, water leak
Help Needed waveydavey00 General PT Cruiser Discussions 6 17 Apr 2012 06:22 pm
how much oil is needed rubyc General Turbo Discussions 4 18 Feb 2011 10:35 pm
air box lid needed gmrviper Classifieds: For Sale/Trade 4 17 May 2008 06:12 am
needed skeeter1620 Exterior Accessories Forum 7 31 Dec 2003 12:01 am
