Cam followers(hydraulic lash adjusters)
Like Tree3Likes
  • 1 Post By rob302
  • 2 Post By Imakenocents
Old 05 Jan 2017, 07:23 pm
Wink Cam followers(hydraulic lash adjusters)
Does anyone know of a tool to remove the lash adjusters with the cams installed? I believe I have a noisy one when the engine is cold. I saw a special tool mentioned in the service manual but that one is expensive. Will another version work to get them out without removing the cams?
Old 05 Jan 2017, 07:52 pm
rob302's Avatar
Default Re: Cam followers(hydraulic lash adjusters)
Schley Products SL99700 Valve Tool - Cylinder Head Tools
Realistically I'm too impatient to order that. I'd study the picture and then make something.
I think handy used one of those and mentioned something about it flying at his head when she slipped... I'm on my phone/can't find it right now
Old 05 Jan 2017, 07:58 pm
rob302's Avatar
Here: http://www.ptcruiserlinks.com/forum/577969-post257.html
Handy_Cruiser likes this.
Old 05 Jan 2017, 09:09 pm
Handy_Cruiser's Avatar
I've got one as already referenced in Rob's link.
They are a little flimsy and the handle is too short. I wrapped the handle in duct tape and stuck a 18 inch piece of PVC schedule-40 pipe over it. This makes it easier to operate with one hand as is required if you don't have a helper. And even then, it takes a little practice to use it. But once you learn to hold your mouth right, you can pull all the rockers without taking the cams loose.
PS: If you put and longer handle on it as I suggest, be very careful. Since it's flimsy, it pops out of place very easily. And when this happened to me, I popped myself in the face with the make-shift handle several times.
Old 05 Jan 2017, 09:49 pm
Wink Re: Cam followers(hydraulic lash adjusters)
Thanks Rob and Handy, I did some more searching and found a Sealey VS168 that I like the looks of and seems to be a little more beefy and compresses evenly across the spring. I guess I'll see when it arrives. Thanks for your input and I'll post an update after I use it or abuse it, which ever might be the case.
3rcruiser and rob302 like this.
brake self adjusters Carl48 General PT Cruiser Discussions 8 12 Aug 2015 03:20 pm
PT Cruiser cylinder head cam followers?? Bandit2014 Tech & Performance Forum 3 22 May 2015 05:54 pm
Hydraulic Handbrake mod cruisin03pt Interior Accessories Forum 1 06 Dec 2012 10:53 am
CAMBER ADJUSTERS FOR GT TURBO GALVANIZEDYANKEE General Turbo Discussions 3 11 Dec 2008 11:30 am
FS: KW Coilover Kit $700 - Springs, Shocks, Adjusters justjeffrey Classifieds: For Sale/Trade 9 18 Aug 2007 03:44 pm
