Oil Light On When Stopped
Old 10 Jan 2017, 09:44 am
Default Oil Light On When Stopped
Bought this 2004 Turbo back in October 2016 with 82,000 miles on it.
Never felt this was right, but whenever I come to a stop (in gear) the car would vibrate like it was idling too low. Last night, I came to a stop light and the oil light came on. I brought the rpm up from about 700 to just under 1000 and the oil light went out.
Thinking it may have been low on oil (dip stick said it was slightly low), I added half a quart. This morning, the problem still exists, only now, the oil light will come on in idle / Park. Rev it slightly and the oil light goes out. (?)
What should I be looking at for starters ?
Thanks,
Mark.
Old 10 Jan 2017, 10:40 am
Default Re: Oil Light On When Stopped
Try the oil pressure sender. I had this pop up around thanksgiving and it popped back up christmas night. If it is the cause be sure to replace with a genuine Mopar part or else it will go out again.
2007 Base model in Cool Vanilla 145,000+ miles
My mods: LED headlights and a K&N Intake
Old 10 Jan 2017, 10:57 am
Thank you very much. Will get that swapped out and see what happens.
Mark.
Old 10 Jan 2017, 11:13 am
Maybe dirty fuel injectors? Try a fuel injector cleaner with the highest amount of PolyEtherAmine you can find. This one has 25-50% http://www.amsoil.com/lit/G2543.pdf?zo=1181889 and you pour into your gas tank. This is a detergent based cleaner, most others are less effective solvent based cleaners.
Old 10 Jan 2017, 11:25 am
I'm assuming this is a suggested cure for the rough low idle and not the oil light ?
Mark.
Old 10 Jan 2017, 11:31 am
Mark.
Might help with both. I've seen low, rough idle, flicker engine and oil lights on other vehicles that seem to go away when idle is higher and smoother.
Old 10 Jan 2017, 11:35 am
Thanks - I'll make that step two.
Mark.
Old 10 Jan 2017, 11:37 am
Mark.
Where do you live, Mark. I'll try to locate some nearby for you.
Old 10 Jan 2017, 11:40 am
About as far south as you can get in Ontario Canada.
Mark.
Old 10 Jan 2017, 12:02 pm
The oil senders are common for failing at and above 10 year old PT Cruisers or with those that have more than 70k miles USA 2.4 model PT Cruisers.
The sensors is not completely friendly to change a little hard to get to.
It is not likely to be anything else nor will anything aside from changing it cure the random activation. The oil circulation system on 2.4 is top notch and seldom fails caused by wear or high mileage. Most failures are neglect of oil and filter changes.
My information is not internet researched but by practical experience. I changed 4 last year and the shop I occasionally work in maybe twice as many. I keep 2 on hand now as part of common PT Cruiser parts that periodically need changing.
AIRTEX is my choice of senders.
Check Engine light, only when stopped at red lights hazeman Tech & Performance Forum 17 24 Sep 2014 06:05 pm
Check oil light goes on & off when stopped at light Triplecat2002 General Turbo Discussions 12 06 Oct 2013 03:45 pm
Stopped for a red light......... tazszzzzzz Welcome New PT Cruiser Members 14 11 Mar 2013 01:10 pm
05 PT just stopped.... brecie Tech & Performance Forum 2 19 Dec 2011 04:08 pm
Sub Stopped CHROMEDCRUISER Sound and Security Forum 6 10 Feb 2005 04:46 pm
