Mph and rpm gauge swap
Like Tree2Likes
Old 15 Jan 2017, 09:31 pm
Default Mph and rpm gauge swap
Is it possible to put the rpm gauge in the middle of the cluster
Old 15 Jan 2017, 09:59 pm
rob302's Avatar
Default Re: Mph and rpm gauge swap
I think i could do it. You would need to switch the needle servos and come up with a way to swap the wires.. Like soldering thin wire back and forth to swap where the wires end up and then figure out how to swap the faces. If the tach face is smaller than the speedo you might need to make a bezel or have a custom face made. You'd have to REALLY WANT TO DO IT
http://www.ptcruiserlinks.com/galler...boCluster7.jpg
Busted_PT likes this.
Old 16 Jan 2017, 01:27 pm
_PTGT03's Avatar
this would involve re-engineering the board and unless you're an electrical engineer with a specialty in pcb design and driving PWM stepper motors it's not going to happen.
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 16 Jan 2017, 02:21 pm
I agree with rob. You would have to have lots of hand skills and really want to do it. Just to get it to the bare board is a task in itself. If I were goin to attempt it would be on a backup. I'm not sure you even have to swap servos. Probably just cross wire the connections. Not fro the inexperienced.
Old 16 Jan 2017, 03:24 pm
rob302's Avatar
^^ and two of the wires to each likely stay the same and just supply power. so you're only talking a couple wires. i said i could do it in my first reply, PTGT03 got me wondering if i can.. so may as well try, eh?
is your car stick or auto? if it's stick, i'll try it. sounds fun. i have the cluster from my (junk)car and i like to nerd around with electronics. , i have a 4yr old boy i borrow to do stuff like this for me. i just point where the wires should go and then beat the kid until he gets it right.
Old 17 Jan 2017, 02:20 am
Well it's kinda confusing. Right now I'm in the process of srt4 swapping my 2001 PT cruiser limited, and I wanted to get some performance gauges. Would a neon srt cluster work with the swap so long as I got the ecu from the neon?
Edit: the car will be a 5 speed getrag or neon trans depending on which I find 1st
Old 17 Jan 2017, 10:12 am
rob302's Avatar
I think that would be a huge headache unless you have the srt wiring harness and you are gifted with wiring. i think i'd want a PTGT harness and cluster. even if it works it may not read accurately. you don't know which trans you're using so you don't know the gear ratios. last time i installed a different speedo i went with a 5" autometer ultralite in dash 160 speedo. it had an electronic sender, and it was able to be calibrated by driving a mile. it was also around $400 for the gauge and the sender
Handy's swap didn't go so well
The "Handy" GT Speedometer Cluster Upgrade
Imo get the car running as intended before you start side projects.
Old 17 Jan 2017, 09:26 pm
Imo get the ca running as intended before you start side projects.
The SRT4 is the same as a PTGT far as the motor goes. He will need to get the pt GT
Garbed and CPU. 01 and 02 will not work. Even a n/a from a 03 up won't work in the first two years.
Old 18 Jan 2017, 02:58 am
All I need to do is get the ecu from the srt4 and it should be fine. If not, I'll just replace all the electronics I need to from the donor to get it working. My cruiser is an 01 limited.
Old 22 Jan 2017, 07:57 pm
https://www.instagram.com/p/BPkp_FGhHL-/
I tested it out on this spare cluster board, so I may just sell this one at some point and use my car's actual cluster, but I'm going to wait until I make new gauge faces.
rob302 likes this.
2004 Touring Turbo Lite, Hahn 20g turbo, ATX ->T350 5-speed swap, mtx stage 1 pcm, DiabloSport InTune, rear sway bar, Wilwood big front brakes, rear disc brake conversion, Drop Zone springs, SRT4 dual exhaust
Can you just swap out the ECM/PCM? Trillion Tech & Performance Forum 6 23 Jun 2016 12:56 pm
WANTED SRT Boost Gauge and SRT EGT Gauge. Hiperguy Classifieds: Want To Buy 4 13 Oct 2010 06:15 pm
this gauge looks too good to be true - does it work ? interceptor gauge mino General Turbo Discussions 3 18 Oct 2007 08:58 pm
2.4l Pt swap fork_in_the_road Classifieds: For Sale/Trade 0 03 Oct 2007 09:21 am
SRT-4......GT Swap... COP TZER Turbo Performance 6 24 Jul 2003 12:34 am
