MSD wires
Like Tree15Likes
Old 16 Jan 2017, 08:26 pm
Default MSD wires
Anyone else have MSD wires? I bought a set of them and short of standing on the plug wire with both feet. They wont snap onto the plug.
2003 PT Cruiser GT - Hand Me Down from Dear Old Dad / Mods: Lowered - Gauges (Boost, Oil Pressure, Volt, EGT, A/F
Old 16 Jan 2017, 09:39 pm
Default Re: MSD wires
I installed a set when I put in my MSD coil... I don't recall having any issues, not sure what might be going on there...? Did you look up in the boots to see if there's anything odd going on there?
Old 16 Jan 2017, 10:51 pm
Not sure about MSD wires, but some ignition wires have you unscrew the caps on the plugs and clip right to the threaded stud on the plug.
wingman55 likes this.
Old 16 Jan 2017, 11:14 pm
Handy_Cruiser's Avatar
I installed a set on my GT. And yes, they were tight.
They sell little packets of grease at the parts stores that are especially made to put on the plugs and boots for this. Also, try each plug out on a loose plug first to make sure the metal part in the boot is in the right position. They can get turned. You should be able to feel the metal part snap onto the top of the plug. If you can't, something is likely not right.
Old 17 Jan 2017, 05:59 am
It seems the little rings are too far up in the boot. I'm going to try and pull them through a little without pulling them off the wire. Worse case I will get another set.
Old 17 Jan 2017, 08:53 am
rob302's Avatar
I've had cheap wires like that. If i had msd wires like that, I'd want them to fix the problem. I fixed mine by gently grabbing the clip inside the boot with a needle nose and pulling it out
Old 17 Jan 2017, 09:20 am
Use Dielectric grease. And on all Performance wres sometimes you need to "burp" them removing air as you push them on the terminals or other components when install them.
You can also apply the DG on the wire and carefully push the wire further down to allow the connector to be closer during installation. Sometime a little common sence is needed.
MSD for the WIN!!!
I will always try to use MSD product first if they have a part for the application I am working on since 1977 and this includes the PT Cruiser.
SPLNeon likes this.
Old 17 Jan 2017, 09:27 am
I can say that it is not likely that there is a problem with the set of MSD wires. If you understood how they are made and packaged it would be extremely rare in a set that more then a couple of wires were incorrectly made let a lone a complete set which really would be impossible!
Old 17 Jan 2017, 11:28 am
Yep, that could well be it too. MSD doesn't seem to be any better than the other major brands at this. Even NitroPT that has an unnatural LOVE for MSD products admits that a couple (two) out of a set of four could be off. That means 50% would need correcting. Plus, I think many MSD wire sets are now made in China. If that's true of the set for the PT Cruiser, then some of what the "old hands" knew about MSD quality in the past may now be somewhat out the window. But you should be able to easily re-position those rings as they should be.
Old 17 Jan 2017, 01:22 pm
It's definitely the wires
which wires? youngcruiser Tech & Performance Forum 7 15 Mar 2006 08:30 pm
Which wires, and where can I buy them? FlySig Turbo Performance 9 01 Feb 2005 05:22 am
8.0 or 8.5 wires? 1lowufo Tech & Performance Forum 5 22 Jul 2004 08:09 pm
2nd set of bad wires tthrift Turbo Performance 12 10 May 2004 01:27 am
Where can i run wires for... VellianPT Exterior Accessories Forum 3 16 Apr 2004 12:03 pm
