ECM Compatibility?
Like Tree3Likes
Old 20 Jan 2017, 04:11 pm
Default ECM Compatibility?
Hello everyone! I have a 2004 PT Cruiser that's been a nightmare for me since I bought it. And today, I find out that I need to get the ECM replaced. My mechanic told me that I need to get an ECM with security in it as my PT Cruiser does have a factory-equipped security system in it. However, right now I'm just trying to find one that's compatible.
I called a pull yard in my area and they said that they have a few '05s and '06s available. I was just wondering, will pulling an ECM out of one of those work with my '04? Or do I have to try and find one for an '04?
Old 20 Jan 2017, 05:18 pm
Default Re: ECM Compatibility?
05 MIGHT work, depending on what equipment it has vs what equipment your 04 has. The 06 or newer WILL NOT work. In 06 the electronics changed completely to the TIPM set up. Don't waste your money on anything newer than 05. Ideally, you need an 04 that's the same # as on yours.
Old 20 Jan 2017, 05:33 pm
So what you're saying is it would be best if I got the part number off the ECM first before I go pulling off one?
Old 20 Jan 2017, 05:49 pm
IF you buy one from the yard, it will need programed by dealer to work with the KEY and SKIM module.
What seems to be the problem you are having.
One other choice is to get the ECM - KEY/key cylinder - SKIM and they will work together but then you would have to rekey your locks
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 20 Jan 2017, 05:51 pm
You also might be able to get the ECU repaired, depending on the problem.
What kind of PT is it by the way? Turbo or non? Manual or Automatic?
Old 20 Jan 2017, 06:55 pm
You should be able to use an 05 in your 04, however as others mentioned, you need to have your car's vin programmed into it before you can use it. If you install it as is, unprogrammed, the vin in the pcm will not match the vin in the skim module, and so the car will not run for longer than a couple of seconds before it shuts itself off.
The dealer can do this reprogramming, if they know how or are willing. Often they will tell you it is impossible because they either do not know how to use their tool to do it, or, they would rather sell you a $600+ replacement. Some other garages with a higher end scanner can do it also, again, if they know how. Many do not seem to know the full capability of their tool.
Syked ecu tuning can do it for $40 plus shipping back and forth. I too can do it for you, but I am located in Canada, and shipping tends to be expensive, but, it is definitely possible.
There is another way to bypass the need for programming, and it is to simply grab the pcm along with the same donor car's key, lock cylinder, and skim module. If you install all of those parts in your car, the security will be satisfied since the pcm and skim VINs match, and the keys are the correct ones programmed in the skim. The downside is that you will have a different key for opening the doors and starting the car. It will save you having to worry about programming though. You could go to a Walmart and buy a replacement cloned key which will clone the replacement key's programming, but cut using your original key. That way your original key will still be able to start and unlock the doors, but have the correct programming for the security.
Often, you can buy a matching set of pcm, key w/lock cylinder and skim on ebay too as well as a plug and play preprogrammed pcm too.
Handy_Cruiser likes this.
Old 20 Jan 2017, 07:45 pm
I know 06 are different but I bought a matched set off ebay for my 06 and I did not have Vin programmed in and all is well...
myckee likes this.
73 Charger SE
01 Sebring flip
Old 20 Jan 2017, 10:33 pm
My '04 is a non-turbo automatic.
Old 20 Jan 2017, 10:44 pm
My problem that I'm having, according to my mechanic, is that its not getting any injection pulse after replacing the crankshaft sensor. He even tried testing the relays, fuses, and wires and everything is coming back fine. There's also no problems with the fuel pump at all.
Old 21 Jan 2017, 10:25 am
Yes, as I mentioned, the set lets you avoid the programming, and as you have experienced, works on the second gens too. It's a great way to beat the cost of mail ordering the programming if you can't find a preprogrammed unit. Usually the ebay sellers charge about the same if it is a matched set, or a preprogrammed unit. I like the preprogrammed method because it is overall less hassle as they are plug and play without needing to swap modules and lock cylinders and potentially have to use multiple keys in the car.
JoeX likes this.
PCM Compatibility nickba General PT Cruiser Discussions 4 16 May 2016 01:06 pm
MAP Sensor Compatibility double_b26 Tech & Performance Forum 4 22 Oct 2012 04:10 pm
radio compatibility brightlight07 Sound and Security Forum 9 27 Oct 2008 08:07 pm
Transmission Compatibility PTmodrod Tech & Performance Forum 6 26 Apr 2008 10:21 am
Hubcap compatibility BeachBum Wheels, Tires, Suspension 0 02 Jul 2007 07:22 pm
