Hand turn starter?
Like Tree68Likes
  #171 (permalink)
Old 15 Feb 2017, 08:40 pm
rob302's Avatar
Default Re: Hand turn starter?
the fuel pump ground is good though, since the car runs. i would stick to tracking down the starting issue... just trying to keep you from running off course. like "fuel pump works, next"
not telling you what to do, just a "think about it" type comment
coastlight likes this.
  #172 (permalink)
Old 15 Feb 2017, 09:32 pm
I agree with Rob302. Just repair the wires for G104 and see if it starts. You don't want to start having more problems by removing wires that might not like it. I think we are all anxious to see your PT Cruiser able to start the engine with the ignition switch.
  #173 (permalink)
Old 15 Feb 2017, 09:50 pm
Yes I know what you mean.
That's a good point. I appreciate your help and I believe what you say is valid. You got my car to start!
I actually have back probes coming in tomorrow and I go and clip the eyelet before I test the TIPM related to the ignition system to verify a bad ground with the back probes. Yet I jump the gun and now I just passed a step I should have waited on.
I am all over the place.
  #174 (permalink)
Old 16 Feb 2017, 05:55 am
LionPT's Avatar
Originally Posted by coastlight View Post
Could you recommend a good wire to use? Thanks.
Go to an auto parts store & buy a roll of 14G or 16G wire, should be under $5.
Use your clippers to get the correct size.
Nexus 5X, Nexus 4, Nexus 7 (2013)
  #175 (permalink)
Old 16 Feb 2017, 12:40 pm
Thanks for the recommendation.
I got 18G, 16G, and 14G wire.
Does it matter if number of strands don't match to original ground wires?
I got 2 wires that match a 16G coil I bought (19 strands). The other 5 wires have 7 strands and look like the 14G wire but don't match in strands.
I called the dealership and it is going to take 1-2weeks prepaid for the 7 strand one - and still they're not even sure its the right one. They are saying its a harness and going off my description and not off the service manual.
Can I still go ahead and use what I got right now for all wires anyways?
  #176 (permalink)
Old 16 Feb 2017, 12:52 pm
LionPT's Avatar
Small or more strands is more flexible...the rating is the same as larger or less strands of the same gauge wire...but harder to bend.
Just match up the thickness of the outside width.
EDIT: 18G is probably too thin.
  #177 (permalink)
Old 16 Feb 2017, 01:17 pm
18G is probably too think & you don't want to create any resistance.
Alright, so number of strands don't matter as long as the rubber insulation is same width when matched.
I think I'm all set then.
I'll update the info once I'm done. Thanks again.
  #178 (permalink)
Old 16 Feb 2017, 07:17 pm
Alright so I was able to do 6 wires today and now I got some more wiggle room with these new wires:
I think the first 2 may have a little bit of resistance because there was a small blob in each wire at the bottom of the new connection (gravity must have pulled it down).
The next 4 wires I did were not fully tinned but not showing too much copper either (to avoid the same mistake of letting gravity build blobs at the bottom again). One the 4 looks like this except with a bit more tin:
1 more to do tomorrow and that should be it. Hopefully it won't have too much resistance due to the 2 small blobs. This was hard work. Sticking fingers down through two pipes was no easy task.
Now it's dark and I have to finish tomorrow.
Would anyone say I should worry about resistance due to the blobs?
  #179 (permalink)
Old 17 Feb 2017, 12:23 pm
Well I feel good getting all wires done now. My last wire is a masterpiece!
However, now when I finish one problem I run into the other. I don't know how to solder all 7 wires into the new eyelet. 7 wires just come out like butter when I pull:
Anybody know how to get the wires to stick to the new eyelet?
I tried to solder the wires to the new eyelet.
I even called the dealership and they don't have any eyelets in the stock but said that I would have to order the whole harness for a week to 2 week period with 1 eyelet attached to it.
Is there a quick solution to this?
ALMOST DONE!! WOOHOO!!
  #180 (permalink)
Old 17 Feb 2017, 12:30 pm
What kind of a soldering iron are you using? Is it getting hot enough?
rob302 likes this.
Diablosport hand held or skyed hand held tuner 707gtcruiser Stage Turbo Kits 7 01 Aug 2016 02:12 pm
Stalled while driving, Starter won't turn over. dfoulkes General PT Cruiser Discussions 2 16 Feb 2016 05:16 pm
starter cranks but motor doesn't turn over aries666 Tech & Performance Forum 1 23 Apr 2015 07:39 pm
Converting a Right Hand Steering PT to left Hand sliver Members PT Project 12 12 Oct 2012 12:11 pm
Left hand turn no wheel stop? xerotime Wheels, Tires, Suspension 2 16 Jun 2009 08:05 pm
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
