Hand turn starter?
Like Tree66Likes
  #181 (permalink)
Old 17 Feb 2017, 01:40 pm
Default Re: Hand turn starter?
Originally Posted by ptcruisersteve View Post
What kind of a soldering iron are you using? Is it getting hot enough?
I was using the soldering gun the whole time.
  #182 (permalink)
Old 17 Feb 2017, 01:45 pm
rckstein's Avatar
You should be able to find a crimp terminal, similar to the original, at an auto store or Radio Shack, the one you are trying to use is a big hunk of copper that will need a torch to get it hot enough to solder to.
'06 Touring Edition NA Automatic
140K Miles / Electric Blue Pearl
USMC '83 - '93
  #183 (permalink)
Old 17 Feb 2017, 01:46 pm
rob302's Avatar
If you have a cheap propane torch, that's the best way to solder that large eyelet. You will never get enough heat there with a soldering iron. For sure.
If that is plumbing flux, it's acid based and will cause corrosion if not removed. Rosin flux is used in wiring for this reason.
rckstein and coastlight like this.
  #184 (permalink)
Old 17 Feb 2017, 01:53 pm
rob302's Avatar
I would have used a smaller eyelet. That's waaaay oversized.
Sometimes i use a hammer to perfect a crimp. Couple good whacks after squeezing it by hand...it helps.
  #185 (permalink)
Old 17 Feb 2017, 03:42 pm
rckstein's Avatar
Top row, far left ring terminal with the yellow insulation is what you need
coastlight likes this.
USMC '83 - '93
  #186 (permalink)
Old 17 Feb 2017, 04:20 pm
Alright I'll try getting a smaller terminal. I saw some at Princess Auto.
I can crimp it and it will be secure? It won't wiggle out over time?
Going to go get some more supplies.
  #187 (permalink)
Old 17 Feb 2017, 04:22 pm
Oh, I used rosin. Acid flux would drive me to the hills if I did that. Was hard enough to even get the first wire soldered in. Took me 2+ hours to figure it out.
Lol. But I got it done. Just this last step with some more tools and it should be good to go.
  #188 (permalink)
Old 18 Feb 2017, 10:41 am
Alright, the update:
I was finally able to get the wires into the copper eyelet using a blowtorch. That took only 5 seconds:
The new connection worked well, at least from just looking at it, because I wasn't able to move the wires around in the eyelet once the solder cooled.
So I put it back into the body panel, put everything back together, and nothing.
I don't know if it's because 5 of the 7 wires had wire strands that didn't match 100% or because my soldering was bad or if I got a problem somewhere else.
Time to keep looking for other grounds.
  #189 (permalink)
Old 18 Feb 2017, 12:59 pm
I would have used 2 or 3 eye/ring terminals as pictured before in a stack up rather than one welding cable lug to accomplish your goal. IMO that is not gonna hold for long. It will hold longer if it has a mechanical crimp along with the soldering you did, but to effectively do that in the car is a challenge without the tools designed for it.
LionPT likes this.
  #190 (permalink)
Old 18 Feb 2017, 03:35 pm
I think I might try to go back in there and do it again. I have those yellow eyelets except mine are red. It will be very difficult now if I have to strip more wire. The wire stripper barely made it down there for the first job.
I recently found 20G wire at another parts store which match the 6 strands I mentioned earlier. For my solder job I used 18G for (5 wires) when I should have now used 20G wire for the 5 wires. This does make a big difference right?
For the other 2 wires I used 16G because they matched perfectly.
Diablosport hand held or skyed hand held tuner 707gtcruiser Stage Turbo Kits 7 01 Aug 2016 03:12 pm
Stalled while driving, Starter won't turn over. dfoulkes General PT Cruiser Discussions 2 16 Feb 2016 06:16 pm
starter cranks but motor doesn't turn over aries666 Tech & Performance Forum 1 23 Apr 2015 08:39 pm
Converting a Right Hand Steering PT to left Hand sliver Members PT Project 12 12 Oct 2012 01:11 pm
Left hand turn no wheel stop? xerotime Wheels, Tires, Suspension 2 16 Jun 2009 09:05 pm
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
