Hand turn starter?
Like Tree68Likes
Old 20 Jan 2017, 07:37 pm
Default Hand turn starter?
Hi everyone. This is my first post.
I own a 2009 PT Cruiser and am having starting issues.
I believe it is either the starter or the fuel line that is causing the problem.
Would anyone recommend turning the belts by hand to assist in starting?
Feedback would be appreciated.
Thank you.
Old 20 Jan 2017, 09:17 pm
Default Re: Hand turn starter?
Welcome to the forum.
I would suggest you put some starter fluid in the throttle body if the engine is turning over but not starting.
Is the engine turning over slowly?
Old 21 Jan 2017, 10:17 am
Thank you.
I think you need to be a little more specific about what your question asks. It sounds (reads) like you want to grab the belts and help turn the engine over while it is being started. I think you will lose some fingers doing that! So the answer to your question is "NO, it is not recommended to turn the belts by hand to assist in starting".
2008, base 4 door, 2.4 NA, Automatic, Silver, 77,000 miles, very clean.
Old 21 Jan 2017, 11:29 am
Is the starter actually spinning the engine over or not? If not, then start with the battery. Check the cables and connections. Check the grounds. If you have a volt meter, check the voltage in it. Should be around 12.5. If all of your connections are good and you hear the starter try to spin the engine and it doesn't, then try tapping the starter with a hammer. The bendix in it might be sticking. BUT under NO CIRCUMSTANCES should you try to assist spinning the engine by hand is someone else is trying to engage the starter with the key. Like stated before, you'll probably lose some fingers.
coastlight likes this.
Old 22 Jan 2017, 12:18 am
Yes I was trying to grab the belts to turn engine. I got a lot of flak for that and I think I'll stay away from that idea.
So basically I think I have a starter or fuel line problem.
My mom's PT won't crank at all. It used to just click constantly when turning ignition but now - nothing.
I charged the battery.
Changed the terminals.
Saw the headlights still on when turning ignition.
Banged the starter a bit.
Nothing.
I recently dropped 1600 on new rad and radiator fan.
Trying to find other ways to take a crack at this without going back to the dealership to drop another brick.
Old 22 Jan 2017, 12:27 am
rckstein's Avatar
Nothing.
Yeah, that's probably not too safe.
Sorry to say, but I think you way overpaid.
Old 22 Jan 2017, 01:52 am
I would suggest getting a voltmeter and check the battery voltage when you are trying to start it. If it doesn't change when you are trying to start it you have an open circuit somewhere.
Also check the voltage coming from the ignition switch to the starter. Post what voltage you have on that wire.
I would also suggest with an ohmmeter check the resistance in both battery cables. Some members have solved the starting issue after replacing bad battery cables.
Ignore the starting system image attached as it is for a 1st generation 2001 PT Cruiser. Yours is a second generation PT Cruiser.
Old 22 Jan 2017, 08:11 am
Even recharging a battery with a dead cell on two in it won't make it work. Take the battery out and take it to your local Advance, Autozone, O'Reilly, NAPA, Car Quest, Pep Boys or whatever other auto parts store that's closest to you and have them load test it. I'll bet your frigging battery is no good. Even the Walmart automotive people can do that for you if you're closer to a Walmart.
Old 22 Jan 2017, 07:23 pm
If you have a battery charger you can check the battery yourself with the help from the link below.
Nitro's way of checking a battery
Old 22 Jan 2017, 07:44 pm
Agree.
Have you tried hooking another car's battery in parallel? (Jumping)
Diablosport hand held or skyed hand held tuner 707gtcruiser Stage Turbo Kits 7 01 Aug 2016 02:12 pm
Stalled while driving, Starter won't turn over. dfoulkes General PT Cruiser Discussions 2 16 Feb 2016 06:16 pm
starter cranks but motor doesn't turn over aries666 Tech & Performance Forum 1 23 Apr 2015 07:39 pm
Converting a Right Hand Steering PT to left Hand sliver Members PT Project 12 12 Oct 2012 12:11 pm
Left hand turn no wheel stop? xerotime Wheels, Tires, Suspension 2 16 Jun 2009 08:05 pm
