Oil Gushing from cam gears
Like Tree4Likes
Old 21 Jan 2017, 04:43 pm
Default Oil Gushing from cam gears
I am assuming that's where the severe oil leak is from as I have reset the valve cover 3 times and used RTV in the required areas. The timing belt I just put on is now covered in oil as are the cam gears. Any ideas of where it could be coming from? The cam caps were torqued to spec.
Disclaimer: There isn't a picture attached because everyone knows what oil covered parts look like.
2003 PT Cruiser GT - Hand Me Down from Dear Old Dad / Mods: Lowered - Gauges (Boost, Oil Pressure, Volt, EGT, A/F
Old 21 Jan 2017, 04:51 pm
Default Re: Oil Gushing from cam gears
..Pressure Wash the engine of all the oil. Start the engine and go look to see where the oil leak is. If it is not readily seen place a piece of cardboard under the engine when it is not running and let the oil drip and follow the trail.
Other wise you either incorrectly installed a part or gasket or overlooked something.
I highly suggest that you get a Factory Service Manual or at least a Chilton or Haynes repair manual if you are going to continue doing most of the work on your PT Cruiser.
Old 21 Jan 2017, 06:03 pm
What procedure did you use installing the cam cap itself? Any sealant used?
Old 21 Jan 2017, 06:28 pm
cam shaft oil seal(s)
Old 21 Jan 2017, 06:34 pm
LionPT's Avatar
Crank seal..??
Old 21 Jan 2017, 07:10 pm
I didn't pressure wash it but cleaned it thoroughly enough to see it was coming from behind the rear timing cover at the cam gears. In reading this I just remembered having a copy of the manual on my laptop. Needless to say the below quote caused me to look and realize, I NEVER INSTALLED THE CAM SEALS !!!!!! I am a F'n IDIOT! I am so pissed off, Now I have to tear it all back down. It wouldn't be such a hassle if it weren't for that stupid frame mount. Thank you, I really do appreciate the feedback. (even if MSD wires do suck )
No, I only made sure I placed the right cap on the right cam. I guess that means I made a drastic mistake.
NitroPT likes this.
Old 21 Jan 2017, 07:22 pm
the cam cap one the seal end has a sealant prrcedure covered in the book to seal and leave drain passages open. Has a wedge of sealant applied so the thick edge is to the outside of the cap on the belt side.
I would clean that belt really good with dawn dushwashing liquid. Oil will break down the belt and cause it to fail prematurely. You can start the engine with or open to be sure everything is ok.
Old 21 Jan 2017, 08:31 pm
A couple of pots of boiling hot water from a tea pot will do wonders for cleaning oil and grease off your engine.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 22 Jan 2017, 03:50 pm
Simple green works well too. I read there is a dye you can put in the oil ad I assume a black light to see where the leaks are.
NitroPT likes this.
Old 22 Jan 2017, 05:01 pm
LionPT's Avatar
Tracer Products Dye-Lite - Gasoline Engine Oil Dye
Used it myself last year.
NitroPT likes this.
grinding gears rob342 Tech & Performance Forum 6 17 Aug 2013 04:54 pm
over rev when changing gears PigFarmer Tech & Performance Forum 5 26 Jan 2012 05:44 pm
skipping gears ProDigit General PT Cruiser Discussions 12 29 Oct 2010 10:09 pm
Education Is Shifting Gears skylight PT Cruiser News and Rumors 0 14 May 2007 06:30 am
cams, cam gears?? proxeyed Tech & Performance Forum 14 18 Jan 2005 12:36 pm
