pt trunk not responding
Like Tree3Likes
  • 1 Post By rsrocket1
  • 2 Post By LionPT
Old 22 Jan 2017, 11:04 am
Default pt trunk not responding
Pt trunk will not open when pushed how do I fix it. I have a 2009 model. I have not found a release button either.lost owner manual to. Thank you.
Old 22 Jan 2017, 12:36 pm
rsrocket1's Avatar
Default Re: pt trunk not responding
Welcome to the forum.
Did you do a search for your problem?
Your doors are unlocked when you do this right?
It won't open if all the doors are locked and you push the rubber touch pad.
Has it ever worked before or is this car new to you?
The rubber touchpad closes a switch which releases the hatch. They do wear out and if it did on your car, you can either replace it with an OEM switch or get a push button switch for a couple of bucks and replace it (again, shown in the forums with a search).
Old 22 Jan 2017, 12:54 pm
Old 22 Jan 2017, 01:15 pm
Old 22 Jan 2017, 04:34 pm
thecabinguy's Avatar
I have wondered this, too, as the touch pad on my '05 just bit the dust recently. Luckily I can still open the hatch up with a key, but that can get a little inconvenient sometimes. I have my owner's manual but nothing stating about replacement of the touch pad.
Prescott, Arizona, home of forested mountains, 5 lakes (well, four lakes and one big pond), and Arizona's Christmas City (my home 6,000 feet elevation) - 2005 Touring & 2002 Limited - both patriot blue & factory stock
Old 22 Jan 2017, 05:07 pm
LionPT's Avatar
You can replace the touch pad, but it only if you replace the entire Chrysler Emblem...it is all 1 piece.
That's why it's just easier to use a push button to bypass it.
rckstein and thecabinguy like this.
Old 22 Jan 2017, 05:43 pm
I read on here before that the hatch release may not be working due to a bad ground. A good indicator would be if you have a third brake light that is also not working. Just a thought.
Old 23 Jan 2017, 11:25 am
rsrocket1's Avatar
Unfortunately, the 2nd gen PT's (mine is an 09 also) don't have a key access for the rear hatch (must have saved Chrysler at least $10 in the cost of the car ).
Do a google search "PT cruiser trunk release" and you'll see lots of threads. It may be as simple as a loose connector or as "complicated" as a worn out or bad switch that needs to be replaced ($) or bypassed with your own $3 pushbutton switch. Here's a good thread.
key/fob doesn't have trunk release, what is needed for remote trunk release? NeonandPT General PT Cruiser Discussions 11 13 Sep 2016 08:40 pm
PT not responding...HELP newpt4me General PT Cruiser Discussions 28 12 Jun 2011 07:43 pm
Trunk Pop delrosen PT Cruiser Convertible Forum 2 27 Jan 2010 04:48 pm
trunk door thomas0810 General PT Cruiser Discussions 4 03 Jan 2010 07:57 pm
Trunk and trunk rack for the PT Cruiser jy_cruiser Exterior Accessories Forum 0 29 Oct 2001 10:32 am
