Draining battery issues
Like Tree4Likes
  #11 (permalink)
Old 22 Jan 2017, 02:38 pm
LionPT's Avatar
Default Re: Draining battery issues
Check the wiring harness above the passenger side front axle.
In the G1's 2000-2005 the hold down clip tends to break causing the harness to drop & rub on the axle...this will cause wires to burn through & break.
  #12 (permalink)
Old 22 Jan 2017, 03:14 pm
Most of the time this happens on the 2001 & 2002 PT Cruisers.
The Crankshaft Position Sensor was easy to replace on the 01-03 models as it was right above the oil filter. In 2004 they moved it to behind/under the starter motor. As a result the wire harness was changed.
  #13 (permalink)
Old 22 Jan 2017, 03:42 pm
Handy_Cruiser's Avatar
Originally Posted by 05cruiser2 View Post
Yes my husband a digital meter and has done the test for the voltage. And you can watch the meter as the car is running going down. He personally took the battery in and watched them test it. The alt was changed because it was bad it was the original. He said the fan was not turning on the inside.
The kind of digital meter needed to detect a drain like this is not the multi-meter most folks have at home. It's a more complex device that has a third lead with a "current clamp".
In the past you could just unhook the battery cable and measure amperage between the battery post and battery cable. But on modern vehicles, the electrical system may not function as it normally does unless a fully charged battery is installed and fully connected. And of course, modern cars also have a normal amount of power drain anyway.
To measure the amount of parasitic drain, you need one of these fancy meters or you can just got to a parts store like Advance Auto and let them test the parasitic drain with their tester.
  #14 (permalink)
Old 22 Jan 2017, 03:44 pm
A simple Digital volt ohm meter would have worked just nicely
I considered who the member was and what level of experience may be there with the suggestion.
Originally Posted by ptcruisersteve View Post
What codes was triggered?
If the PT Cruiser has a major short draining the battery the link below will help you find the short by pulling one fuse out at a time but first we need to find out if the generator is charging.
How to Find a Parasitic Battery Drain: 9 Steps (with Pictures)
If you are not positive the battery is good the link below might help determine if the battery is good or not.
Nitro's way of checking a battery
Tags
alternator, battery, car dies, draining, won't stay running
2003 Base PT, Issues with interior fuse #13 draining battery goforce Tech & Performance Forum 7 21 Nov 2016 09:30 am
Battery Draining or Dead wraithracing General PT Cruiser Discussions 11 15 Feb 2014 09:03 pm
Radiator Fan Draining Battery CruZn4ABruZn General PT Cruiser Discussions 5 10 Dec 2010 06:54 pm
2005 PT Turbo convertible battery draining. Deen General Turbo Discussions 10 21 May 2010 11:57 am
