Fog lights
Old 23 Jun 2004, 01:29 am
Default Fog lights
FOR SOME REASON , I CANNOT FIGURE OUT HOW TO GET THE FOG LIGHTS TO TURN ON. I HAVE CHECKED THE FUSES AND PULLED ON THE END OF THE LIGHT SWITCH, BUT NOTHING WORKS...ANY IDEAS???
Old 23 Jun 2004, 01:40 am
This may sound stupid but did you check the bulbs? My Dodge Caravan sport had foglamps and BOTH bulbes went out at the SAME time.
2k3 Electric Blue Touring, N/A, K&N dropin, Silencers removed, Snorkle Replacement, BTG Catback Single Tip Exhaust. \"Technogrounding\", Custom Painted interior, 2k1 5 spoke wheels painted black, Next Destination: Hahn Stage 1. (alas! the perils of insufficient funds)
Old 23 Jun 2004, 01:44 am
I WILL GIVE IT A TRY... AM I CORRECT ON PULLING ON THE END OF THE LIGHT SWITCH TO TURN ON THE LIGHTS?? THE CAR DIDNT COME WITH AN OWNERS MANUEL SO I AM NOT TOO SURE IF I AM DOING THIS RIGHT...THANKS
Old 23 Jun 2004, 09:07 am
Montanez,
First Take off the CAPS LOCK...it's like shouting on the internet. Second, yes pulling out the end of the stawk will do two things...turn on the running (amber) lights and turn on the fog (white driving) lights. The fog lights won't work until you have the high, low or running lights on. Do the rest of the functions on the stawk work..ie left and right turn signals, high & low beam headlights? Some owners have had problems with the multi-function stawk itself. ALSO, the number #8 fuse (15A) in the fuse panel by your left knee is the fuse for the fog lamps...check it out.
Old 23 Jun 2004, 09:12 am
Minor correction - fog lights won't come on if high beams ("brights", and a blue light on dash lights up) are on, only low beams & running lights (first and second clicks on the same stalk you pull out). If high beams are on, pull stalk toward you, then pull outward on stalk for fogs.
Old 23 Jun 2004, 11:00 am
[quote]Originally posted by quicksilverdon
[brMinor correction - fog lights won't come on if high beams ("brights", and a blue light on dash lights up) are on, only low beams & running lights (first and second clicks on the same stalk you pull out). [quote]
Picky, Picky, Picky !!! It's probably the fuse anyway. []
Old 23 Jun 2004, 12:09 pm
Is there a way to make the foglamps come on when the brights are on?
Has anyone used those ultra bright headlamps? What is involved with switching to such a system?
Old 23 Jun 2004, 04:19 pm
I changed both the low beam headlights and the fog lights to the ultra white lights. Got them all at Wal-Mart. The fog lights are easy to get to, just a rubber flap between you and the connection as your lying on your back. The headlight can be changed by going thru the oblong port in each of the wheelwells. They're a little bit of a hassle as the space to work with isn't very big, but it can be done.
Old 24 Jun 2004, 12:36 am
Thanks for the advice guys..I have tried all of the mentioned troubleshooter tips but still no fogs. I am feeling that there is a problem with the stawk itself....notice the CAPS are off? Thanks again. 2001 Limited Edition all stock for now...Montanez
Old 24 Jun 2004, 08:08 am
Well, you're not alone:
http://www.ptcruiserlinks.com/forum/...chTerms=switch
I've read that replacing the multi-function switch isn't that hard...
Hella fog lights question PoconoPT Tech & Performance Forum 3 17 Jun 2010 11:28 pm
PT Cruiser 1959 Cadillac tail lights available Marge Classifieds: For Sale/Trade 4 23 Oct 2009 02:31 pm
LIghts, Lights, Lights King_Rob Classifieds: For Sale/Trade 4 20 May 2005 09:14 pm
Problem with fog lights TaylorMade General PT Cruiser Discussions 6 13 May 2004 07:41 am
APC Next Generation Tail Lights Jeff V Exterior Accessories Forum 10 21 Mar 2003 01:17 am
