Headlight goes out
Old 23 Jan 2017, 01:39 pm
Default Headlight goes out
I have a 2009 pt cruiser. Replaced the headlights entirely around Christmas. I put new led bulbs in my low beams. They both worked fine for a while. However now the passenger one will go out after about 10 minutes. Could this be a fuse issue or the connector. I put in these bulbs: XKGLOW Single Beam 60W COB LED HB3/9005/9011
Old 23 Jan 2017, 07:45 pm
rob302's Avatar
Default Re: Headlight goes out
I would swap the right and left bulbs. Same problem? Try two standard bulbs.
Could be the tipm doesn't like one of both of those LEDs
Old 23 Jan 2017, 09:52 pm
This is a common problem on the second generation PT Cruisers with the TIPM. Several members have had to replace the TIPM to get the passenger low beam to work again. As Rob says check the bulb by switchig with the drivers side and make sure the new bulbs doesn't draw more current then the original ones.
Old 29 Jan 2017, 09:10 pm
Get a load resistor for each side. Had to do the same thing. Have had them in for 5 months now. Still going good.
Tags
headlights
Headlight ? red98gt Exterior Accessories Forum 2 09 Feb 2015 05:53 pm
Headlight ? red98gt Exterior Accessories Forum 5 27 Jan 2015 10:40 pm
right headlight beakerss General PT Cruiser Discussions 2 10 Aug 2011 10:56 am
Headlight mod... CYCLONE_06 Exterior & Interior Styling 20 11 Mar 2011 02:56 am
Headlight help bhunt41 Exterior Accessories Forum 8 17 Feb 2011 04:11 pm
