A/C & Heater Controls
Old 23 Jan 2017, 09:15 pm
Question A/C & Heater Controls
Hi Everyone,
This morning the left knob on the vent controls didn't work. It's stuck on the defrost mode. Does anyone know where that cable attaches to? The a/c and recirculate buttons work as well as the heater know and flap.
The knob isn't broken and the cable is fastened to the back of the control module. There was a cracking noise this am so I figured the module might be bad on the left side.
Any ideas to trouble shoot?
Thank you in advance
2006 PT touring edition, 5 spd manual, 140K, MSD 8.5 mm wires, Champion plugs
Old 23 Jan 2017, 09:24 pm
LionPT's Avatar
Default Re: A/C & Heater Controls
Originally Posted by discovering06 View Post
Hi Everyone,
Did you remove the center bezel to check..?? if a hold down clip is broken, the cable will have too much slack. Follow the cable from the knob to where it connects...looking for damage at both ends.
Old 23 Jan 2017, 09:27 pm
rckstein's Avatar
I would take the cable off the back of the knob, then see if you can turn the knob, or operate the cable manually, that should isolate the problem to one or the other.
Old 23 Jan 2017, 09:56 pm
Question Re: A/C & Heater Controls
I removed the center bezel when the vent knob is turned the cable moves. Does anyone have a diagram where that cable goes. I opened the glove box and tried to follow it. There is normal tension of the cable and took it if the knob seems to function properly.
Old 23 Jan 2017, 10:14 pm
LionPT's Avatar
This might or might not help
Control-Cables/Removal-Installation
Heater Controls - Swapping out bulbs for LEDS Prostheta Interior Accessories Forum 5 15 Nov 2018 06:56 am
Internal Heater/vent controls rhino169 General PT Cruiser Discussions 3 28 Oct 2014 03:52 pm
Awkward Controls on 08 PT Princess General PT Cruiser Discussions 13 08 Jun 2013 09:30 am
heater controls 4b316 Tech & Performance Forum 1 11 Jul 2009 07:25 am
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
