Need Advise on Transmission repair
Like Tree2Likes
  • 1 Post By chuzz
  • 1 Post By esoess
Old 26 Jan 2017, 11:42 pm
Default Need Advise on Transmission repair
I just had my car in the shop due to my waterpump going out and they replaced the timing belt and water pump. When I picked it up I was told my tranny was 4 quarts low and they said I had a leak at my (front) control Module. I am not a mechanic and have no clue what this is. He said about $90 to fix it. Is there such a thing and does it leak. Just want to make sure I am not getting told something because I am uninformed. I am planning on getting a second opionion also.
Thanks All.
Old 27 Jan 2017, 12:52 am
Default Re: Need Advise on Transmission repair
Thanks All.
I would suggest not driving it with the transmission 4 quarts low on oil.
You will need to verify where the transmission leak is before getting an estimate to fix it.
Old 27 Jan 2017, 08:11 am
Was the car driving and shifting okay BEFORE you took it in to the shop? If so, I'd say they're trying to screw you over. If not, then that's a cheap enough fix. I just find it very hard to believe there wouldn't have been some type of shifting issues if it was a gallon low on fluid. BUT, I'm not a mechanic, so what do I know, right?
JoeX likes this.
Ignorance can be educated, crazy can be medicated, but there IS no cure for stupid.
Old 27 Jan 2017, 02:40 pm
I was not noticing any issues shifting at all.
rob302 likes this.
Old 27 Jan 2017, 03:20 pm
rob302's Avatar
I read this as the shop cared enough to check the fluids, added four quarts, notified him of the leak, and quoted him a good price to fix a messy job.
Otherwise they would not have known it was four quarts low. I think we've all seen how much the trans fluid level changes on the dipstick adding even a small amount of fluid.
Don't be so hard on the shop... all threads, not just the one. IMO
Help! Need advise please Chrissy78 Northeast PT Forum 8 19 May 2016 10:06 pm
stripped transmission bolt holes. How to repair? Flash619 General PT Cruiser Discussions 21 28 Mar 2015 08:22 am
To keep or not to keep. Need advise. jazzbot General PT Cruiser Discussions 22 11 Nov 2011 12:20 am
Need advise about amps NkBkGt Sound and Security Forum 8 25 Mar 2004 12:45 pm
Buying advise please Bryans1265 General PT Cruiser Discussions 4 07 Sep 2003 10:12 pm
